block comparison.
Old Aug 15, 2002 | 05:15 PM
baonest's Avatar
Default block comparison.
some of u know that my block is built LS with JE 11.5 pistons, sleeved, 84mm, eagle rods, and the crank is micropolished. i heard on here that my block wont be compared to an ITR block because its not VTEC. well doesnt the itr block have 10.0 pistons? whats the bore on them. my block should beat out the ITR block. dont LS blocks have more displacement, or is it the other way around.
or does that extra oil line that is tapped on the head make my block loose all its power.
and if the ITR block is better... should i consider a trade in the near future??
Old Aug 15, 2002 | 05:39 PM
baonest's Avatar
Default Re: block comparison. (baonest)
Old Aug 15, 2002 | 06:01 PM
Tommy_Gunns's Avatar
All b-series have the same sized bore (I think). It is the stroke that gives it the different displacements.
Old Aug 15, 2002 | 06:03 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: block comparison. (Jay_Dee_Mmm)
Type R = 1797cc
81mm bore, 87.2mm stroke
Courtesy 2000 ITR brochure
Old Aug 15, 2002 | 06:09 PM
baonest's Avatar
Default Re: block comparison. (Splat)
how could i find the stroke on my LS block.?
back to subject, is my block same/better than ITR?
Old Aug 15, 2002 | 06:53 PM
Splat's Avatar
http://integra.vtec.net/geeser/specs.html
89mm stroke for RS, LS
That site also shows the following displacements:
RS, LS - 1834cc
GS-R, Type R - 1797cc
Old Aug 15, 2002 | 07:40 PM
green_GSR's Avatar
Stock vs stock, LS block has weaker sleeves compared to B18C1/5. I also believe that LS block don't have block girdles.
Since your block is resleeved (84mm), therefore I don't think your block is weaker than a B18C1/5. All you need is a block girdle to strengthen up the block.
BTW, USDM ITR comes with 10.5:1 CR.
Old Aug 15, 2002 | 08:05 PM
baonest's Avatar
Default Re: block comparison. (green_GSR)
yah, im currenlty getting a girdle. so everythings up to par
Old Aug 15, 2002 | 08:22 PM
Taloola's Avatar
BTW, USDM ITR comes with 10.5:1 CR. yah, im currenlty getting a girdle. so everythings up to par
i was under the impression that usdm itr comes with 10.6:1 compression...can't forget that .1 extra
as far as your block goes.....i would say as you have about 1973cc of dispalcement. only thing i can think of that your ls block doesn't have are those oil squirters, but i don't think it should be a big concern since you using aftermarket pistons
[Modified by gokoolFL, 5:36 AM 8/16/2002]
Old Aug 15, 2002 | 08:27 PM
Louie's Avatar
What would Chente do?
Default Re: block comparison. (gokoolFL)
ITR crank is lighter/stronger/ better balanced...more counterweights. But i'm not absolutely positive..Better to just IM sgt.
Old Aug 15, 2002 | 09:21 PM
sgT's Avatar
sgT
Dont bother with a main girdle unless you install dowels and have the mains
align honed.
Also if you are SOOO worried about being compared to a vtec block you should
just install the oil cooler and oil jets and then the ONLY difference will be the
external vtec line.
Old Aug 15, 2002 | 09:23 PM
sgT's Avatar
sgT
Default Re: block comparison. (Louie)
Lighter? no
stronger? maybe
better balanced? easily remedied
Old Aug 15, 2002 | 09:24 PM
sgT's Avatar
sgT
GSR = 1760cc's
LS = 1860cc's
I am unsure about an ITR block... Would like to know though...
SHEESH, where did those numbers come from?
Old Aug 16, 2002 | 02:43 PM
baonest's Avatar
Default Re: block comparison. (sgT)
GSR = 1760cc's
LS = 1860cc's
hehe.. sgT has the answers to all of our Q's..
Jimmy
Sep 28, 2013 05:34 AM
02vtecsir
Jul 5, 2008 03:33 PM
AMS MIKE
Aug 4, 2007 07:21 AM
KtotheEK
Apr 15, 2005 05:07 PM
B18C GSR CIVIC
Feb 6, 2004 12:16 PM
