Bleeding coolant
Old Oct 17, 2003 | 07:16 AM
KRiS1's Avatar
Default Bleeding coolant
Is thier a coolant bleed valve on a 01 B18C5? I looked at an integra helms and saw one but couldnt find one where it is supposed to be on my motor
Old Oct 17, 2003 | 01:31 PM
KRiS1's Avatar
Default Re: Bleeding coolant (KRiS1)
Old Oct 17, 2003 | 01:33 PM
RTW DC2R's Avatar
on the radiator? I dont know if the stock radiator has a drain plug or not.
Old Oct 17, 2003 | 01:37 PM
KRiS1's Avatar
Default Re: Bleeding coolant (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">on the radiator? I dont know if the stock radiator has a drain plug or not. </TD></TR></TABLE>
Not on the radiator, on the actual motor
Old Oct 17, 2003 | 01:47 PM
sackdz's Avatar
Yea there is a plug on the front of the block to the left of the dipstick.
Old Oct 17, 2003 | 01:51 PM
KRiS1's Avatar
Default Re: Bleeding coolant (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Yea there is a plug on the front of the block to the left of the dipstick.</TD></TR></TABLE>
Isn't that just the drain bolt for the block?
In the helms it shows a bolt with a nipple on it that you loosen to bleed air out of the system. Its shown as being located on the thermostat housing, below the distributor, where the upper radiator hose comes in.
Old Oct 17, 2003 | 02:04 PM
Austin's Avatar
Form what I remember it states to remove the radiator cap and let it run for a little while, the bubbles will find their own way out, no bleed screw. When I pulled the intake manifold, and when I changed the thermostat this is the method that I followed, no issues.
Austin
Old Oct 17, 2003 | 05:13 PM
sackdz's Avatar
Default Re: (Austin)
When I flushed my system I just ran it with that bolt out while filling the radiator with water. I'm not using coolant but if you just run the motor for 15 seconds or so you should be good.
Old Oct 17, 2003 | 06:27 PM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRiS1 &raquo;</TD></TR><TR><TD CLASS="quote">
In the helms it shows a bolt with a nipple on it that you loosen to bleed air out of the system. Its shown as being located on the thermostat housing, below the distributor, where the upper radiator hose comes in.</TD></TR></TABLE>
Like Austin said, no bleeder on the R.
Old Oct 17, 2003 | 07:24 PM
t's Avatar
t
You looking at an old helms for a B16 motor? Honda eliminated that nipple because it keeps breaking. In fact if you order one with a nipple from Honda, you will get one without.
Old Oct 17, 2003 | 07:56 PM
KRiS1's Avatar
Default Re: Bleeding coolant (t)
I was looking at a helms for 94-95 integra.
I just bled the old fashioned way last night and everything turned out good. Ran the car around town for a couple hours today in 90+ heat with the AC on full and no problems at all
Old Oct 17, 2003 | 08:26 PM
Fuuma0083's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">Form what I remember it states to remove the radiator cap and let it run for a little while, the bubbles will find their own way out, no bleed screw. When I pulled the intake manifold, and when I changed the thermostat this is the method that I followed, no issues.
Austin</TD></TR></TABLE>
This is the way i have always been doing it without any problems. (let it run of a awhile and watch the water slowly drop and just keep adding more water.
avargas28
Jun 29, 2008 01:07 PM
Dredakid05
Apr 20, 2008 02:53 PM
mysicivic1991
Apr 19, 2007 10:57 AM
missionaryrider
Jun 21, 2005 09:19 PM
FD3S
Apr 20, 2003 04:22 PM
