Battery problem
Old Aug 25, 2008 | 06:28 PM
Devon M's Avatar
Default Battery problem
I searched, but didn't really know how to search for it. I was at the gas station today, I went in paid, as i walked out my car alarm went off. I turned it off, filled up, got in my car and my clock and radio reset. My battery must of cut out or something. This isn't the first time. A couple weeks ago I thought I stalled out, but my clock and radio reset as well. It shut my car off. Also another problem that could be related is my car doesnt let me in sometimes. I hit unlock on my keyless, and it unlocks but when I pull the handle it locks again. Any ideas? Thanks.
Old Aug 25, 2008 | 06:31 PM
eluam's Avatar
Aftermarket or factory remote/alarm?
Old Aug 25, 2008 | 06:32 PM
Devon M's Avatar
Default Re: (eluam)
Factory.
Old Aug 25, 2008 | 10:45 PM
Kavehman's Avatar
check the gorund terminal on the battery, maybe its jumping.
You should look into a decent alarm too
Old Aug 25, 2008 | 11:02 PM
Devon M's Avatar
Default Re: (Kavehman)
I checked the ground terminal already, it is as tight as it gets but i can still pull it off. What do you do about that? Yeah, I need an alarm really bad, my tires are bald, and I am about to move. I need some serious cash.
Old Aug 26, 2008 | 01:02 AM
Haleiwa-Brando's Avatar
Default Re: (jdmeg6b18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6b18b &raquo;</TD></TR><TR><TD CLASS="quote">I checked the ground terminal already, it is as tight as it gets but i can still pull it off. What do you do about that? </TD></TR></TABLE>
Simple...you fix it I'm not sure what you have exactly going on with the battery terminal, maybe take a picture and post it up. Or if it looks as though you can tighten the terminal down better by adding or deleting a washer somewhere, try that. That may simply be your problem.
Heck, while your at it, may as well pull off both connections and give the battery terminals a good roughing up with fine grit sand paper.
Old Aug 26, 2008 | 03:21 AM
Cheeze's Avatar
Default Re: (Haleiwa-Brando)
Definitely tighten up that battery terminal..If you can pull it off after tightening it, most likely its not making good contact thus causing your issues...either replace with a new terminal, or use some visegrip or sumthin and squeeze the terminal a lil to make it a lil smaller so you'll have a snug fit. Goodluck!
Old Aug 26, 2008 | 09:06 AM
Devon M's Avatar
Default Re: (Cheeze)
Thanks, thats most likely the solution for the car turning off. What about the ghost locking the door when i pull the handle? lol
Old Aug 26, 2008 | 09:14 AM
eluam's Avatar
My terminal was the exact same way. I loosened it all the way, pushed it down as far as it would go on the terminal and it tightened down. Hasn't come loose again and its been 6 months since I tightened it. Used to pop off once a month before.
Old Aug 26, 2008 | 09:38 AM
mugenr#1011's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6b18b &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, thats most likely the solution for the car turning off. What about the ghost locking the door when i pull the handle? lol</TD></TR></TABLE>
mine has the same problems with the door handles i have a viper two way alarm with pager. but when i hit the unlock buttton you can hear it unlock. the driverside door has to be opened with the key and sometimes when i pull on it it locks everything else its weird
FredHawley
Dec 8, 2017 07:04 PM
CeeJayy
Audio / Security / Video
Nov 12, 2008 06:33 PM
barefootbilly
15
Jun 3, 2004 01:54 PM
Prod
Jan 13, 2004 01:29 PM
spdster
Dec 29, 2001 11:18 AM
