balancing?
Old Jul 7, 2002 | 12:28 PM
B_CRUZ!'s Avatar
Default balancing?
I have a CM 9.5Lbs light weight flywheel on my B18C and I was told it was balanced from the factory. I already installed it on my car and I was wondering if I can/should still get it balanced with my crankshaft. Would I have to remove the block from my car? can they balance it with the motor still in the car? where do I bring it to get balanced?
I know some of you R owners have aftermarket lightweight flywheels... did you guys worry about it?
Old Jul 7, 2002 | 12:39 PM
SlapSmak's Avatar
Default Re: balancing? (B_Cruz)
the crank is balanced by itself, if the flywheel has been balanced, then when you bolt the two together, they will be balanced.
Old Jul 7, 2002 | 05:15 PM
B_CRUZ!'s Avatar
Default Re: balancing? (SlapSmak)
thanks
Honderachinaldo
Engine Machining & Assembly
May 14, 2019 09:25 PM
DJP
36
Jul 31, 2007 02:31 PM
.Thomas
Jan 16, 2007 10:45 PM
SioneSi
12
Feb 25, 2004 07:03 PM
Scooby
Jun 28, 2002 01:07 PM
