B18C5 - Weird diagnostic code... help?!
Old Aug 6, 2008 | 10:08 PM
TheDanimal's Avatar
Default B18C5 - Weird diagnostic code... help?!
I have a JDM B18c5.
It has been throwing codes, which I originally thought was because of my secondary 02 sensor... I took it to a tech I know at a Honda dealer & he pulled the codes for me.
The o2 sensor was throwing codes, but there were two others that stumped us both.
Does anyone know what these two codes are?
P2828
POAOA
Thanks!
~Dan
Sidenote: I brought the car in because she's been bogging recently. The RPM's will jump and drop occasionally when there's positive or negative change in throttle - but never when it's wide open.
My guy suspects the secondary o2 sensor is acting up again, not picking up heat and affecting my 'normal' driving - and causing the problem
...thought I'd throw this in just in case it helps :D
Old Aug 6, 2008 | 10:11 PM
SuckMyDOHC's Avatar
what ecu are you using? The JDM P73 for the B18c doesn't use the secondary O2
Old Aug 6, 2008 | 10:28 PM
TheDanimal's Avatar
Default Re: (SuckMyDOHC)
The ECU came with the engine...
Bear with me here... I'm know some stuff, but am retarded with half this ****... I'm still learning as I go :D
p73?
Koyoloeor
Oct 13, 2005 04:57 PM
draxxus07
Sep 29, 2005 11:35 AM
EF4lyfe
Feb 14, 2005 05:43 PM
Cody M
Mar 16, 2003 05:18 PM
GarageQueen213
Jan 31, 2002 06:00 AM
