B18C5 Compression
Old Mar 22, 2003 | 03:46 PM
RRRex's Avatar
Default B18C5 Compression
I just bought a CRX with an ITR engine transplant. Before I bought it, I had a compression test done. Through all cylinders it was around 8 I think. I was expecting higher. Any theories. Engine feels strong and pulls really good and emissions passed without a Cat.
Old Mar 22, 2003 | 03:47 PM
jonas's Avatar
Default Re: B18C5 Compression (RRRex)
compression was around 8? lol.. your motor has problems.
Old Mar 22, 2003 | 03:52 PM
SoCal ITR's Avatar
Default Re: B18C5 Compression (jonas)
Passed without a cat? Was the engine on?
Compression should be over 200, shouldn't it?
Unless you're talking about cr with should be 10.6:1
Old Mar 22, 2003 | 04:26 PM
Mr Hammond's Avatar
a/k/a Jomo
What kinda compression test was that man?
Old Mar 22, 2003 | 07:34 PM
-iLLuZioN-B18C1's Avatar
LOL, either your doing it wrong or you had a major typo
Old Mar 22, 2003 | 08:29 PM
markpaco's Avatar
Default Re: B18C5 Compression (jvithayapun)
maybe 8 bar since he is from CDN. If that is true, then that is 116 psi which is not good.
Old Mar 22, 2003 | 08:34 PM
jond's Avatar
CRX with an ITR engine transplant from Toronto. Flame me if you want, but the sound of that makes me ill.
Old Mar 23, 2003 | 07:34 AM
ITR1299PR's Avatar
Well man i have test my R and the compresion was 265 psi in all of the pistons. My internals are stock.
Old Mar 23, 2003 | 10:32 AM
RRRex's Avatar
Default Re: B18C5 Compression (ITR1299PR)
I think the compression test was done wrong - and it did pass emissions without a cat. Weird. Thought for sure it would fail, but it scraped by. I have all the papers for the motor - only 60K on it. Took it to the track last year and pull 14s. For a first time at the track I was happy with that. Couldn't keep the wheels from spinning in first. So I don't think there's anything wrong with the motor. I just thought that maybe the pistons might have been changed for a turbo build up that never happened. It's going back on the road soon and I'll get it redone.
Old Mar 23, 2003 | 12:07 PM
jonas's Avatar
14 what in the 1/4? that sucks for a b18c5 in a CRX IMO.
Old Mar 23, 2003 | 04:38 PM
Mr Hammond's Avatar
a/k/a Jomo
Yeah man. I mean not to flame but 14's? I just watched a 92-95 HB with a B18C1 (USDM GSR) swap with intake only run 13.9 on the motor and 13.1 on a 60shot earlier today. Not to bad for for stock exhaust manifold, stock cat and crappy stock civic exhaust. Your CRX should run mid 13's on the motor with bolt-ons and a half way decent launch. Hell I watched a stock ITR run 13's with AEM/open JDM 4-1 and no P/S or A/C belts on.
Old Mar 23, 2003 | 07:04 PM
RRRex's Avatar
Default Re: B18C5 Compression (Mr Milano)
No, you're totally right. I should be in the 13s but I can assure you it's all driver - put my autocross tires on thinking I'd get a better launch but if you saw my slips you'd see how wrong I was. Did hit 98mph though. I have a GSR tranny with long gear ratios better suited for autocross and unfortunately no LSD - so launches are never going to be great. I only did the 1/4 to see what all the fuss what about. Requires a lot more skill then I gave them quarter mile guys credit for - but I think I'll stick to the twisties.
Old Mar 23, 2003 | 07:07 PM
RRRex's Avatar
I just needed to know what the right compression needs to be so when I get it retested I have something to compare it to and if there's a rational reason for the compression to be low across all cylinders. From the looks of it from your posts it seems to me the test was wrong. Thanks.
Old Mar 25, 2003 | 03:45 PM
neogenesis2004's Avatar
Do you mean that the cylinders varied by around 8psi? If so then your ok!!!
Old Mar 25, 2003 | 05:58 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Do the compression test again.
Remove the spark plugs and hold the throttle open while you crank.
Last time I did it I got 250'ish on all four.
It also depends on engine temperature, if you do it on a cold engine it will give lower numbers.
Type 56
Engine Machining & Assembly
Aug 13, 2017 06:34 PM
thirsk66
22
Jul 1, 2012 11:04 AM
CTR_B
Apr 22, 2008 04:27 PM
EG6 Love
Feb 15, 2008 05:06 PM
lude98SH
Dec 18, 2006 04:39 PM
