Another width/offset question....
Old Oct 2, 2007 | 10:23 PM
Morty's Avatar
Default Another width/offset question....
hey guys just seeing if anyone has any experience running
8 inch wheels with a +48 offset.
looking a set of 16x8 48+
just seeing if people have issues with rubbing on the outter edges
My R is fairly low
thanks again
Old Oct 2, 2007 | 10:29 PM
YellowKahuna's Avatar
Default Re: Another width/offset question.... (Morty)
Im going to say its a no go.
+33, 35, 38 are the offsets you might want.
Not too sure though ask Phat R or JUNR, Yellow Blur, Toddo
Modified by YellowKahuna at 12:43 AM 10/3/2007
Old Oct 2, 2007 | 11:44 PM
sheekdude's Avatar
Default Re: Another width/offset question.... (YellowKahuna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowKahuna &raquo;</TD></TR><TR><TD CLASS="quote">Im going to say its a no go.
Not too sure though ask Phat R or JUNR</TD></TR></TABLE>
Not to threadjack but, thanks, I was about to buy some wheel 17x7.5 with a +48 offset...
Old Oct 2, 2007 | 11:57 PM
Doostur's Avatar
Ouch tough one. It wont rub but damn it will be close. ask nsxtasy
Old Oct 3, 2007 | 05:07 AM
cmdr430's Avatar
16x8 w/48 offset is better than 16x8 w/33-35-38 offset
the higher the offset# the further the wheel sits inward the wheel well....
the lower the offset # the further outward the wheel sits in the wheel well....i.e rubbing your wheel well lip/fender
Old Oct 3, 2007 | 06:29 AM
highroller54's Avatar
Default Re: Another width/offset question.... (cmdr430)
^^^ yes but I think 48 will get you into the trailing arm in the rear
Old Oct 3, 2007 | 08:42 AM
Morty's Avatar
Default Re: Another width/offset question.... (highroller54)
appreciated guys
look at something closer to 16x7 with a 42ish offset?
Old Oct 3, 2007 | 08:55 AM
Mr.OB*GYN_Rhett's Avatar
here you go: https://honda-tech.com/zeroforum/56
Old Oct 3, 2007 | 10:12 AM
white rocket's Avatar
16x7 +42mm is fine. 17x7.5 +48mm is fine also. With 16x8 you'd be better off with a higher positive offset; however there is a fine line. Too low and you'll rub on the fender or fender liner. Too high and you'll rub in the rear on the trailing arm. I'm sure there are plenty of ITR peeps that have run an 8" wide rim. Perhaps they'll chime in.
Old Oct 3, 2007 | 12:47 PM
Black R's Avatar
25 Year Member
Default Re: (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">16x7 +42mm is fine. 17x7.5 +48mm is fine also. With 16x8 you'd be better off with a higher positive offset; however there is a fine line. Too low and you'll rub on the fender or fender liner. Too high and you'll rub in the rear on the trailing arm. I'm sure there are plenty of ITR peeps that have run an 8" wide rim. Perhaps they'll chime in.</TD></TR></TABLE>
Speaking from experience, I wouldn't go any higher on offset than +40 for a 7.5" wheel on a dc2.
8" wide, ideally you need about +25 offset. You can get away with a little higher - maybe +35 but that's about it. This is due to clearance issues with the rear trailing arm and control arm.
Do yourself a favor and run some 225 tires on an 8" wide wheel. Just say expletive it and roll those useless fenders!
Old Oct 3, 2007 | 03:58 PM
Morty's Avatar
Default Re: (Black R)
thanks again guys
picked up some 16x7 +45 today
Old Oct 3, 2007 | 04:31 PM
Doostur's Avatar
^ Perfect
triple
Honda S2000
Apr 20, 2007 09:32 PM
lil_Ek9
Honda S2000
15
Feb 9, 2007 10:13 PM
fkncivic
Sep 20, 2006 11:03 PM
h22teg
Honda S2000
12
Sep 9, 2006 11:29 PM
130R
14
May 31, 2005 10:38 AM
