Adding a JRSC?
Old May 31, 2002 | 06:36 AM
SCsol's Avatar
Default Adding a JRSC?
guys im adding a JRSC to my ITR what cams do you guys run with the JRSC, i have a set of crower stage 2 Vtec cams in now, will these be good to use with the JRSC. What cams are you guys running?
Old May 31, 2002 | 07:26 AM
csufweed's Avatar
Default Re: Adding a JRSC? (SCsol)
no, but you may be able to dial out some overlap with cam gears... but im not promising that you'd make any more power than if you had stock cams.
Old May 31, 2002 | 07:52 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
I'd sell the cams and use the money to buy some of the extra stuff you'll need to make power with the JRSC. If you don't already have a VAFC, get one. Same goes the Jackson MAP controller and a better FPR (like a Cartech) would be a good idea too.
For lots of good tech info on JRSC ITRs, talk to Rboosted717. His is the best setup one that I know of.
Old May 31, 2002 | 08:44 AM
DCtwoR's Avatar
Default Re: Adding a JRSC? (newt2)
you definitely want the JR MAP and a better FPR, I like the vortech. The JR BTM is a nice add on too. Wish I had that stuff when i had my supercharger on.
Old Jun 2, 2002 | 12:37 PM
Mr Hammond's Avatar
a/k/a Jomo
Hate to break it to you, but it's been proven time and time over then anything other then stock cams are pretty much shitty when in combo with a JRSC. Even the ITR/CTR are pushing it. You can try messing around with the cam gears, but i havent' seen a successful combo with aftermarket vtec cams and a jrsc.
later.
97_BB6
Mar 12, 2007 10:35 PM
TypeR0936
Jun 3, 2002 05:42 PM
SCsol
Jun 2, 2002 12:39 PM
Halo
Jun 23, 2001 01:16 PM
