ABS problem
Old Mar 11, 2006 | 04:03 PM
Daniel M.'s Avatar
Default ABS problem
Hi!
I have a EG6 Civic with everything swapped from a ITR.
I have also swapped the whole ITR ABS system and bakes.
The problem is that the ABS works realy slowly, I have the wheel lock for a few meters, the unblok for a fraction of a sec. and block again for an other few meters and so on.
The Abs light never came on but I wanted to see if there was any error code and error 81 appeard.
What can it be?
Old Mar 11, 2006 | 09:38 PM
Track rat's Avatar
Default Re: ABS problem (Daniel M.)
Check all of your ground cables. Sand the chassis contact points clean and re attached the ground cables. See if that helps.
I painted my engine compartment while the motor was out for a rebuild. My abs wigged out during my next track day due to poor grounding.
Old Mar 11, 2006 | 11:57 PM
Daniel M.'s Avatar
Default Re: ABS problem (Track rat)
I tried to do also a few tests ona a sandy road wit 2 wheels on the sand and 2 wheels on dry road and the wheels on the sand stay loked.
It also seems as If I lock the 4 wheels.
Is there a way to reduce the rear brake pressure?
epeen
Dec 24, 2005 11:12 AM
fcuked
23
Jan 18, 2004 08:42 PM
ophdehEEzY
Mar 7, 2003 09:36 AM
JAME CHANOBI
Mar 6, 2002 09:06 PM
