Mad ABS light problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR »</TD></TR><TR><TD CLASS="quote">wheel sensor maybe
if u have a manual u can check the code?</TD></TR></TABLE>
Don't need a manual. Check out this thread and post your code:
https://honda-tech.com/zerothread?id=978933
Thanks for you help so far...I was able to get a 4 main code and 8 subcode. The book tells me its the rear left speed sensor.
Next, is this the driver side rear or passenger rear and where exactly is this speed sensor located?
No, but the car did sit for about 4months without moving and when eventually moved the rear wheels did drag a little bit to break free.
Anyway can anybody still help me on where the rear wheel sensor is?
on my 92 gsr the abs rear wheel sensor went, it was pretty simple to find..just look around your rear brake assembly you'll see a black line coming out if it somewhere that goes across the whole underside of the rear of the car. It's hard to accurately explain where it is, i'm sure if you look around there you'll find it though, I had no idea where it was when I did mine but after a few minutes I found it. Good luck.
vic-in-long-isl
10
Jul 11, 2011 06:07 PM
