ABS Light?
Old 06-26-2006, 12:06 AM
DC231_01's Avatar
Default ABS Light?
Searched many times and found many things..
Just wondering if our ABS setup is the same as all other integra's and all you have to do to reset the ABS is pull the ABS2 fuse? Just replaced my clutch and now after about 500 miles on it, the ABS light popped on.
I didn't take anything off plug wise. Didn't remove the ABS sensor, so I'm thinking it just need's to be reset? Thanks for the help in advance..
Old 06-26-2006, 08:01 AM
hypeR speed's Avatar
Default Re: ABS Light? (DC231_01)
i've had abs codes for the longest time and resetting the ecu wouldnt clear it. it turns out after reading the helms, abs codes are stored in an eprom on the abs computer. the way to reset it is to jump the scs, hold the brake, turn ignition to on, wait for abs light to turn off release brake, wait for abs light to turn on then brake again and it should be cleared. if the codes pop up again then you know you have a problem
Old 06-26-2006, 01:02 PM
DC231_01's Avatar
Default Re: ABS Light? (hypeR speed)
So it is differant. That's what I thought, but I didn't have anyone to confirm it. Thanks for the help, me and my trusty paper clip are on a mission now..
Old 06-26-2006, 03:32 PM
DC231_01's Avatar
Didn't work for me..WTF! I'm just going to pull some fuse's hopefully that erase's the ABS's memory..
Old 06-26-2006, 06:19 PM
DC231_01's Avatar
Don't know if it was supposed to work, but it did... SCHWEEEET!
Old 06-26-2006, 07:32 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypeR speed &raquo;</TD></TR><TR><TD CLASS="quote">i've had abs codes for the longest time and resetting the ecu wouldnt clear it. it turns out after reading the helms, abs codes are stored in an eprom on the abs computer. the way to reset it is to jump the scs, hold the brake, turn ignition to on, wait for abs light to turn off release brake, wait for abs light to turn on then brake again and it should be cleared. if the codes pop up again then you know you have a problem</TD></TR></TABLE>
almost sounds like an old school NES Contra cheat code everyone remembers
Old 06-26-2006, 08:21 PM
Chris F's Avatar
Default Re: ABS Light? (JUN.R)
up down up down left right left right a b a b brake gas paperclip fuse
Old 06-26-2006, 08:37 PM
JjuuN R's Avatar
Default Re: ABS Light? (Chris F)
hahaha nice twist Chris
jrmullins85
09-24-2015 05:40 AM
Lost Type R
03-22-2003 07:32 PM
DC5 Type-R
03-08-2002 05:52 PM
Quick Reply: ABS Light?
