98 vs 01 ITR intake cam
Re: 98 vs 01 ITR intake cam (Austin)
Nice...now can you do that with Brand XXXX cams...
there's also nice programs out there with little hardware kits like cam doctor, dr. cam... etc... does it automatically for you and can be input into some of the more popular engine simulation programs. we don't have a cam dr. at school as of yet, but if i want to go out of my way i could certainly have a friend toss some effort at it.
my data wasn't exact, and i had to eyeball TDC, but i ended up with 11.4906 mm lift (as opposed to 11.50 published... that is, unless vegeta beat a thou off this cam). {also, assuming 1.56 is the correct rocker ratio... someone confirm if they wish, i forget}
D
Re: 98 vs 01 ITR intake cam (Johnny Tran)
fugg all this honda ****.........i wanna see some SB2 charts bitch.
D
Re: 98 vs 01 ITR intake cam (D)
you want SB2 flow #'s???? (goes to look thru his chit)
D
D
intake valve lift (in) SB2 flow (CFM) - rounded
.100 74
.200 161
.300 216
.400 286
.500 338
.600 359
.700 365
D
.100 74
.200 161
.300 216
.400 286
.500 338
.600 359
.700 365
D
now thats tizzite! pushrods own your azz
nick, who will discuss the finer points of smallblock chevy motors this weekend over a fine malt BEvERage with MAtt
2001 should be better than 98 and of course! otherwise there will be no improvement for honda!!!
but they test 98 spec and 20 spec, it's same time for the 1/4 mile
Re: 98 vs 01 ITR intake cam (YelLowITR)
Re: 98 vs 01 ITR intake cam (Zygspeed)
Which ones are the "turbo" cams?
I know that for turbos you still want a long duration just not as high lift cam.
Re: 98 vs 01 ITR intake cam (ITR21)
where did that come from and what are u talking about.
Hurry up and do the 98 Cam I am about to do this swap myself . . . .
Re: 98 vs 01 ITR intake cam (Asahi)
I think you missed the inside joke. . . . .
hehe ... thanks .... FYI, less overlap, otherwise you waste the boost!
I was just wondering if the 2001 ITR intake cam is the same as the JDM CTR intake cam.....Does the CTR intake came have 3 degree more duration than the 98 ITR cam also?
Global Moderator
Re: 98 vs 01 ITR intake cam (JDM_ITR)
Anyone in FL got a CTR IN cam for Matt to evaluate?
Re: 98 vs 01 ITR intake cam (Reid)
They are similar for sure. Identical? That is uncertain.
