'96 Spec JDM
Old 03-23-2018, 01:30 PM
  #376
Klasse's Avatar
Default Re: '96 Spec JDM
Originally Posted by Tom B
Cheers. Yes, Capital. Didn't replace the covers. A little tricky to be honest. I took a load of pictures so I could do a write up. Having said that I read a 'how to' on another forum and was confident to tackle the job with my experience and tools.
Always enjoy a good write up! I have been putting it off a bit as I'm worried about them going back together the same. I have an extra pair and possibly want to use to two passenger seats to make a good set. Will involve swapping the ***** over etc and new bolsters
Old 04-09-2018, 07:57 AM
  #377
Tom B's Avatar
The caR had it's MOT inspection last week and passed with zero advisories, of course.
Old 04-09-2018, 08:26 AM
  #378
Tom B's Avatar
Replaced heR front lower arm bushings, compliance bushings and front stablizer links with new OEM parts. Full OEM Honda rebush complete.
Manage to damage the sleeve of one the lower arm bushings as I pressed it in. Doesn't seem to effect anything but it's a shame. Should I replace it, what do you guys think?
Old 04-09-2018, 09:09 AM
  #379
dave7's Avatar
What kind of cat do you have?
Old 04-09-2018, 09:50 AM
  #380
Tom B's Avatar
This one Japanese performance car parts, cheapest Japanese car accessories UK, JDM car parts M2 JDM Spec Adjustable Decat Pipe (2.5")
previous owner fitted.
Old 04-13-2018, 07:48 AM
  #381
Tom B's Avatar
Decided I will replace that bush.
Cleaned the air filter and changed the oil and oil filter. Went with OEM Honda oil and filter. I also cleaned the door hinges and surrounding area then regreased the hinges with white lithium grease.
Old 04-13-2018, 07:57 AM
  #382
dave7's Avatar
Oem oil FTW
Old 04-13-2018, 10:40 AM
  #383
white rocket's Avatar
Very clean. Great work
Old 04-23-2018, 07:54 AM
  #384
Tom B's Avatar
Got the damaged bush replaced with another new OEM part. I have to say the car feels very nice to drive with the new bushings, it really does feel 'newer'. The old ones didn't 'look' bad but the new ones have made a difference without a doubt. Just need to have the alignment checked now.
Old 04-26-2018, 02:23 AM
  #385
Tom B's Avatar
Fired some of this inside the front subframe. I've already used it in every box section and crevice on the rest of the car.
Old 04-29-2018, 07:47 AM
  #386
Tom B's Avatar
Cleaned heR and went for a drive. She drives so nicely with the new bushes. Hoping to drive more this summer.
Old 05-01-2018, 01:18 PM
  #387
feck's Avatar
Nice one! but tickle me pink and colour me shocked. No surprise there T. Your car is better than when Honda first sold it.
+1000. Unless the shocks and springs are totally knackered with crazy mileage on them, changing out the bushes makes the biggest difference in my humble. Double wishbone suspension setups are better in more than a few ways, but one of their disadvantages is more bushes than Central Park and they tend tow ear out more quickly(even when looking OK) and when they wear out that slop is felt more keenly. That and the expense are likely the biggest reasons Honda and everyone else outside of exotics went the McPherson strut type layout, cheaper to build and fit and with fewer bushings and wear is less noticeable.
Old 05-05-2018, 11:46 AM
  #388
Tom B's Avatar
How'd you work that out? haha. It's not bad I guess.
I agree, mine didn't look bad at all really. The shocks and springs I have are OEM 98' Spec with about 81k on them and seem very good. If money was no object I'd buy new OEM ones I think.
Old 05-05-2018, 12:19 PM
  #389
Tom B's Avatar
Fixed the rear hatch upper seal with 3M double sided tape. Pictures below for **** and anyone else.
First thing is to put some tape or a towel on the roof to protect it.
Use a plastic trim tool to pry up the part of the seal that's come away. Then pull it onto the tape or towel on the roof.
Now start picking/pealing off the old tape. I used another plastic trim tool.
Once you've got the worst off, wipe the seal with iso or panel wipe.
Fit the new tape and trim the edges. You'll need sizes of about 10mm and 5mm width.
Push the seal back under the bootlid in position and then simply open the hatch all the way and it will push the seal onto the hatch. You could help start it by using a right angled tool to press it on but opening the hatch does most of the work.
And there you have it.
FYI you can't replace the seal without removing the glass from the hatch but I think this is the next best thing. Most of the tape used on the Integra is 3M so you could say it's still the way Honda made it :-)
Old 05-06-2018, 11:09 AM
  #390
Tom B's Avatar
I cleaned the front subrframe, suspension and applied some Bilt Hamber Dynax UC anti-corrosion wax. Did the same on the rear suspension.
Old 05-06-2018, 11:23 AM
  #391
Tom B's Avatar
One of the bumper bolts was stripped and spinning inside the front cross member, I found this out the last time I put the bumper on. I cut the end off with a Dremel and then drilled the rest of it out and used a M6x1.0 thread repair kit. Also ran an M6x1.0 tap threw the bolt hole on the other side to clean the threads up and fitted new OEM bolts.
She still looks clean behind the bumper. I was toying with the idea of removing the undercoat but after having seen a '96 Spec on one of the Best Motiring videos with undercoat in the same area, I think I'll leave it alone.
Old 05-06-2018, 01:11 PM
  #392
feck's Avatar
Damn that car is a credit to you. Real concours stuff going on.
Good How To on the rear seal thingie. Over the last few years I cobbled together loadsa spare bits and bobs for the future, among them was a rear hatch, so I can do the seal off the car which'll make it much easier. I also notice you guys recently got the same dusty rain we got in the other damp island off the coast of Europe.
Old 05-08-2018, 02:15 AM
  #393
Tom B's Avatar
I promise that's as dirty as she gets haha. I usually wash heR every week or every other week at worst.
Old 05-08-2018, 02:27 AM
  #394
Tom B's Avatar
Had a small gremlin to deal with that I tackled now the weather over here has improved. Small amount of rust on the front right chassis leg. Sanded back to smooth, clean metal, wiped over and then used Bilt Hamber Electox Zinc Rich Primer followed by Championship White and a sprinkle of clear coat. These areas barely have any clear on them from factory. I also sanded back and painted the torque mount bracket. I used my Genuine Honda Civic EG body repair manual for paint repair reference because I like things done to OEM standard, in case you hadn't noticed.
Before.
After.
Reassembled.
Old 05-08-2018, 07:36 PM
  #395
330R's Avatar
^ That turned out great! I really like your attention to detail and wanting to keep things as close to OEM original as possible. In the EG Civic body repair manual, did it have specifics about the paint to use on the torque mount bracket? I'd like to know what Honda recommends. Some people go with powdercoat or any of a variety of rattle-can black paint, but I'm a stickler for the details, as well.
Old 05-09-2018, 12:42 AM
  #396
Tom B's Avatar
No, not for the bracket. They do mention this colour but for certain areas of the body like rear tow hook and front member area, NH-86. I used VHT satin black wheel paint. It's a good match.
Old 05-14-2018, 05:55 AM
  #397
Tom B's Avatar
Old 05-14-2018, 08:49 AM
  #398
ddwelch's Avatar
I love popping in this thread from time to time, and seeing all the amazing progress you have done on this caR bringing it as close to original as possible.
Old 05-16-2018, 05:56 PM
  #399
stin1's Avatar
Curious why you are using 10w-40 vs 5w-30 or 10w-30 ? Mine don't seem to like any thing over 10w30. Even using high mileage Mobil 1 the car didn't seem to like it. I had to change my shift points for normal driving or it would bog . Ended up going back before the oil change was due it bothered me so much. Nice ride. Digging your thread. You should put on itrca too.
Old 05-16-2018, 09:42 PM
  #400
Tom B's Avatar
I’m using 5w40.
Quick Reply: '96 Spec JDM
