Z10 alignment specs...
I took the Teg into the alignment shop to have it checked after installing the z10 kit. I wasn't having any problems, I just wanted to have it checked since it's been a year since I bought the car.
I have the rods set at 3.5 turns CCW with the car on the ground. Having the weight on the wheels when making the adjustment will result in a more accurate set-up. The specs came out to the following with me in the car:
Camber LT -1.75 RT -1.5 degrees
Caster LT +1.5 RT +1.5 degrees
toe in -1/8
The stock caster specs for the 95 Teg are 1 degree 10 minutes +/- 1 degree.
I've got the car lowered about 1.5" in front so the camber is about right. No appreciable inside tire wear.
I thought about backing off the rods to see what the caster was stock, but didn't have time. As I mentioned earlier the steering is heavier than stock, but the car feels much better at speed, and corners much more surefootedly.
toe in -1/8
b18c4door
Nov 2, 2003 08:52 AM
Rwecked
Sep 7, 2003 05:10 AM
