alignment should be done ____?
Old Aug 31, 2006 | 05:26 PM
DC4GB's Avatar
Default alignment should be done ____?
Alright guys I recently had to do some work to the teg, which required me to jackup the front. I've noticed that after lowering my car to the ground, the front wheels seem to have more / \ negative camber. Is this a problem, and would I need an alignment?
Old Aug 31, 2006 | 05:57 PM
trick_db's Avatar
Default Re: alignment should be done ____? (DC4GB)
well is up to you, it just going to wear out your tires, thats why you need to buy a camber kit,.. how much of a drop? if is 1.5-2.0 is ok, other then that is too much and camber kit will help
Old Aug 31, 2006 | 06:02 PM
JDM_DC4_Fanatic's Avatar
excessive positive, or negative camber will not only wear ur tires out faster, but you lost traction. You arent using the whole contact patch of the tire...you should have it adjusted by a reputable alignment shop. Also, make sure the shop that you are taking it to, has the right program for lowred cars. The alignment machine at our shop will only give factory specs, not nessicarily the specs needed for a dumped car.
Old Aug 31, 2006 | 06:06 PM
DC4GB's Avatar
well i dropped my car previously and got it aligned. my fenders are sitting flush with the wheels, with maybe about a finger's gap. i know my specs from the alignmenr were fine, but i was just wondering if my specs would change by merely jacking the car up and down. any input would be helpful
Old Aug 31, 2006 | 06:08 PM
Racermech's Avatar
Default Re: (DC4GB)
Did you remove or do anything to the suspension?? Including the sway bar.
Old Aug 31, 2006 | 06:19 PM
DC4GB's Avatar
i didn't touch the suspension at all. i was asking this question because the wheels seem to dip inwards more than before. i installed a lip to my car, that's the reason i jacked it up, so i could get under.
Old Aug 31, 2006 | 06:26 PM
jdm_bones's Avatar
you should be cool dude, unless you tweek your suspension...then you need a new alignment, but jacking up your car won't take it out of alignment...
Old Aug 31, 2006 | 06:28 PM
trick_db's Avatar
Default Re: alignment should be done ____? (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">you should be cool dude, unless you tweek your suspension...then you need a new alignment, but jacking up your car won't take it out of alignment...</TD></TR></TABLE>
is not just jacking up his car, but he lower his car, thats mean depend how bad it is, then you need aligment, plus it only cost 40 bucks.
Old Aug 31, 2006 | 06:45 PM
jdm_bones's Avatar
Default Re: alignment should be done ____? (trick_db)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">
is not just jacking up his car, but he lower his car, thats mean depend how bad it is, then you need aligment, plus it only cost 40 bucks. </TD></TR></TABLE> Thanks for the correction, some how I missed that, thanks!
To the OP, how much did you drop it?
Old Aug 31, 2006 | 06:48 PM
b18integ's Avatar
everytime u adjust the height of the car alwayz get an aligment..
Old Aug 31, 2006 | 06:52 PM
trick_db's Avatar
Default Re: (sdr 94integ)
that true, but how much of a drop, by droping a 1.5 inch doesnt necessary need alignment. is all depend on what you want basicly
Old Aug 31, 2006 | 07:24 PM
ac_attak's Avatar
Holy crap can any of you guys read? He said he had his car lowered and it was aligned already. All he did was jack the car up to install a lip, and he wants to know if jacking the car up and down would throw his camber off.
I cant see how that would throw your camber off. Are you sure it is any different then before?
Old Aug 31, 2006 | 07:26 PM
trick_db's Avatar
Default Re: (ac_attak)
umm, he say he jsut lower his car, he asking us if he should need alignment... ????
Old Aug 31, 2006 | 07:30 PM
ac_attak's Avatar
Default Re: (DC4GB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4GB &raquo;</TD></TR><TR><TD CLASS="quote">but i was just wondering if my specs would change by merely jacking the car up and down. any input would be helpful </TD></TR></TABLE>
Thats pretty clear to me what he is asking.
Old Aug 31, 2006 | 07:35 PM
trick_db's Avatar
it wasnt the op, doesnt have the time to read every post, sorry
Old Aug 31, 2006 | 07:51 PM
atg1290's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4GB &raquo;</TD></TR><TR><TD CLASS="quote">Alright guys I recently had to do some work to the teg, which required me to jackup the front. I've noticed that after lowering my car to the ground, the front wheels seem to have more / \ negative camber. Is this a problem, and would I need an alignment?</TD></TR></TABLE>
And that is the op...I havent gotten my car aligned yet but ive heard you dont need an alignment every time you jack the car up...it might jsut be your poaranoid like 80% of us
steveharrmr23
Sep 9, 2008 12:10 PM
zach1288
42
Nov 18, 2007 06:12 PM
Spoonerz
Apr 19, 2007 02:35 PM
Ludeboi
Apr 25, 2003 11:26 PM
team ugly
Jan 30, 2003 08:53 AM
