wuts the diff
Old Nov 4, 2005 | 08:50 PM
94IntegraLs04's Avatar
Default wuts the diff
i wanna know wuts the diff between an itr water pump from a gsr one.
Old Nov 4, 2005 | 08:54 PM
blkb18's Avatar
Default Re: wuts the diff (94IntegraLs04)
i dont think there is a difference.
Old Nov 4, 2005 | 08:56 PM
Default Re: wuts the diff (blkb18)
o idk i heard something thts idk iam askin to c if anone knows thnx
Old Nov 4, 2005 | 09:00 PM
blkb18's Avatar
huh?
Old Nov 4, 2005 | 09:12 PM
gsrvtec2's Avatar
dey r the same, only LS if diff
Old Nov 4, 2005 | 09:52 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: wuts the diff (tekneshum)
can a gsr or type r bolt up to a LS??
Old Nov 5, 2005 | 12:25 AM
mjc1055's Avatar
Default Re: wuts the diff (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">can a gsr or type r bolt up to a LS??</TD></TR></TABLE>
Yes but you'll need a different timing belt.
Old Nov 5, 2005 | 12:38 AM
blackdelslo's Avatar
Default Re: wuts the diff (mjc1055)
One pumps regular water and one pumps tuned race water duh
Old Nov 5, 2005 | 12:59 AM
95TegSE's Avatar
From my understanding they're the same...the oil pump, is also the same between GSR and ITR...even though you didn't ask
Old Nov 5, 2005 | 06:31 AM
Default Re: wuts the diff (95TegSE)
thts koo i didnt know tht
Old Nov 5, 2005 | 10:52 AM
fridayfred3p's Avatar
Old Nov 5, 2005 | 05:28 PM
Johnny_Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekneshum &raquo;</TD></TR><TR><TD CLASS="quote">dey r the same, only LS if diff</TD></TR></TABLE>
... what?
Old Nov 5, 2005 | 05:56 PM
JERKthisDC2's Avatar
there the same
Old Nov 5, 2005 | 07:51 PM
HT Black OPs
Default Re: wuts the diff (JdmJerk.Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes but you'll need a different timing belt.</TD></TR></TABLE>
Will this effect any other part on my LS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">From my understanding they're the same...the oil pump, is also the same between GSR and ITR...even though you didn't ask</TD></TR></TABLE>
Can this also bolt up to a LS?
Old Nov 5, 2005 | 07:55 PM
Baron55's Avatar
difference??? The hype r difference
Old Nov 5, 2005 | 11:45 PM
mjc1055's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">Will this effect any other part on my LS?</TD></TR></TABLE>
No, as long as you have the correct belt matched with the correct water pump, it will run as if stock. The belts themselves are pretty close, the vtec belts just have a few more teeth, I believe.
Old Nov 6, 2005 | 10:28 AM
1Bar GSR's Avatar
Type R and GSR waterpumps are the same part number. Type R and GSR oil pumps are different... the type r is said to be better.
Old Nov 6, 2005 | 10:36 AM
b18ccivics's Avatar
the only difference in any of te b series water pumps is the number of teeth on the pump, that is why the belts are different. i think but not for sure it has been a while but there is eather 19 or 22 teeth
Old Nov 6, 2005 | 11:17 AM
riceball777's Avatar
ls water pump is 19 teeth
itr and gsr water pump is 22 teeth
and yes the itr and gsr is the same
you must use a gst.itr timing belt with the itr/gsr water pump
same goes for the ls
Old Nov 6, 2005 | 01:29 PM
h22 dc2's Avatar
Default Re: wuts the diff (riceball777)
hi im new i have a h22 dc2 all motor
Old Nov 6, 2005 | 01:53 PM
nitrofish420's Avatar
Default Re: wuts the diff (h22 dc2)
Kick ***, but post about it in your own thread.
CRJenkins13
Dec 18, 2007 03:22 PM
Eklsv-t
Dec 1, 2007 06:06 PM
CivicVX94
Nov 27, 2006 05:45 PM
I got a honda
Aug 1, 2005 10:42 AM
Phatch99
May 23, 2005 03:59 PM
