Would a Main Relay cause my car to die?
Old 08-26-2008, 05:36 AM
96WhiteOnBlack's Avatar
Default Would a Main Relay cause my car to die?
I`ve been searching for 2 days and finally may have come to a conclusion. It sounds like my Main Relay is the problem. But I couldnt find wheather or not it would cause my car to die while on interstate. Anybody know? Thanks in advance!
Old 08-26-2008, 05:42 AM
HONDRETTI's Avatar
Default Re: Would a Main Relay cause my car to die? (96WhiteOnBlack)
no it wouldnt cause your car to die while driving. it would cause it not to start.
Old 08-26-2008, 05:50 AM
I'm a Jackass
neardon's Avatar
Default Re: Would a Main Relay cause my car to die? (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI &raquo;</TD></TR><TR><TD CLASS="quote">no it wouldnt cause your car to die while driving. it would cause it not to start.</TD></TR></TABLE>
Hmm weird, it caused my car to stop running while on the freeway. Basicly you're saying the only way for a relay to go bad is if the car is turned off first and it cant go bad while the motor is running. That has to be the dumbest thing i've ever heard use common sense before posting false info next time.
Old 08-26-2008, 05:52 AM
Reject Papi
jhammond_82's Avatar
Default Re: Would a Main Relay cause my car to die? (neardon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neardon &raquo;</TD></TR><TR><TD CLASS="quote"> you're saying the only way for a relay to go bad is if the car is turned off first and it cant go bad while the motor is running. </TD></TR></TABLE>
good point.....
Old 08-26-2008, 06:59 AM
SuzukaBlueAP2's Avatar
Default Re: Would a Main Relay cause my car to die? (jhammond_82)
There is current passing through the main relay all the time when the vehicle is running. If the relay should go bad while the car is running then the engine would shut off as it controls the fuel pump and injectors.
Turn all devices off in the car (radio, heater controls, etc.) and turn your key to the 'on' position. You should hear the relay click 3 times. (if i remember correctly it is behind the dash). I would have to pull up a electric diagram to find out for sure.
Any ways, if it clicks 3 times the relay is fine and your problem is elsewhere.
Old 08-26-2008, 07:24 AM
Default Re: Would a Main Relay cause my car to die? (SuzukaBlueAP2)
I cant hear the relay making any noise what so ever. A Honda machanic told me that if its not the relay my ECU may be fried. But I got a code reader and got the codes off if it. Would I have been able to get the codes off an ECU that was fried?
And when you say "click" 3 times..... is an actual clicking sound? The reason I ask is that when I turn my key it beeps under the dash. I put my ear right next to the Main Relay and I can hear any clicking at all.
You guys are Awesome! Thank you very much for all your help! You have no idea!
Old 08-26-2008, 07:40 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
it is an actual clicking noise. the ECU causes it to click, IIRC. A lot of the wires for the relay come from the ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">There is current passing through the main relay all the time when the vehicle is running. If the relay should go bad while the car is running then the engine would shut off as it controls the fuel pump and injectors.
Any ways, if it clicks 3 times the relay is fine and your problem is elsewhere.</TD></TR></TABLE>
You sure it clicks 3 times as normal? I guess I'll have to start my car and listen later.
Old 08-26-2008, 07:42 AM
Default Re: Would a Main Relay cause my car to die? (B serious)
I'm pretty sure...
I don't have my Teg anymore so I can't go listen to it. But I will listen to the one in my S and Fit and see what they do.
And I still have the Teg electronics manual at home, I'll have to look there as well. I thought it was 3. But my mind may not be what it used to be.
Old 08-26-2008, 07:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96WhiteOnBlack &raquo;</TD></TR><TR><TD CLASS="quote">
I don't remember beeping...it should be a definite click.
Can you put your hand on it while you turn the ignition on? You will definitely feel the stages of the relay opening.
Old 08-26-2008, 07:55 AM
Yeah, I can do that. I`ll go try that and let you know. Thanks man!
Old 08-26-2008, 08:05 AM
nolaB18's Avatar
YES, the main relay can cause your car to die. However it usually prevents the car from starting by not supplying power to the fuel pump. The reason i say this is because my dad has a 97 TL and his car would be running smooth as glass then all of a sudden it would die. $80 and a new main relay later from my local acura dealer and the car has never done this again in over 3 years. My teg's main relay went out a few months ago and it would be a pain to start, i would have to literally tap the main relay, (the grey box above the driver side kick panel with the big plug) for it to click on .
Old 08-26-2008, 08:10 AM
Ok, I didnt feel anything. I tried it 3 times and felt nothing all 3 times.
So a Honda machanic told a friend of mine that if its not the Main Relay then the ECU is probably fried. But would I have been able to get codes off of a fried ECU? Cause I got the codes it was throwing.
Old 08-26-2008, 08:17 AM
nolaB18's Avatar
if you don't hear of feel it click i wouldl say its the relay before the ecu
Old 08-26-2008, 08:47 AM
Default Re: Would a Main Relay cause my car to die? (nolaB18)
I would assume so.
Old 08-26-2008, 09:11 AM
b17rider's Avatar
juss throwin this out there my old DA did that and it was the ignition coil
Old 08-26-2008, 09:31 AM
Default Re: (b17rider)
Is the ignition coil the same as the coil in the dizzy? If so, I already changed it and that didnt do anything.
Old 08-26-2008, 09:35 AM
Default Re: (96WhiteOnBlack)
Well, I ordered a new one from Honda a few minutes ago. It was $65 for it and to get it overnighted. I got a pretty good discount through my work, about $30 total.
I`ll change that out tomorrow and let you guys know what happens! Thanks again to everybody!
Old 08-26-2008, 09:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96WhiteOnBlack &raquo;</TD></TR><TR><TD CLASS="quote">Is the ignition coil the same as the coil in the dizzy? If so, I already changed it and that didnt do anything. </TD></TR></TABLE>
Correct. The ignitor is under the cap and rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96WhiteOnBlack &raquo;</TD></TR><TR><TD CLASS="quote">I ordered a new one from Honda a few minutes ago.
keep us posted! good luck!
Old 08-26-2008, 10:24 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure...
And I still have the Teg electronics manual at home, I'll have to look there as well. I thought it was 3. But my mind may not be what it used to be. </TD></TR></TABLE>
I have an EM1 and an AP1. I'll listen for it in the EM1. I would guess it would be the same for a GSR.
Old 08-26-2008, 10:29 AM
racebum's Avatar
test your ignitor, team integra has an article on how to do so. ECU's almost never die.
Old 08-26-2008, 10:59 AM
egsleepercivic's Avatar
you may not here it click, have someone turn the key to on with your head on the back seat, see if you can here the pump prime
Old 08-27-2008, 07:11 AM
raj_very's Avatar
i had my distributor gone when my car stopped running while driving. may be its distrubutor
Old 08-27-2008, 12:08 PM
Default Re: (raj_very)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raj_very &raquo;</TD></TR><TR><TD CLASS="quote">i had my distributor gone when my car stopped running while driving. may be its distrubutor</TD></TR></TABLE>
You had your distributor gone?
I'm not even sure what that's supposed to mean...
Well guys, it wasnt the Main Relay. I got the part this morning and replaced it. It didnt change anything.
The people at Acura were kind enough to take the part back and charge me a 25% restocking fee. Better than not getting any at money back at all.
Im about to take out my ECU and check for anything that looks electicly burnt. This is turning into Hell!
I wanna thank everybody for thier input! Furnther advice would still be great as I dive into the pits of Hell also known as my floor board!
Old 08-27-2008, 12:13 PM
When I replaced it, I still didnt hear or feel the relay clicking
Quick Reply: Would a Main Relay cause my car to die?
