Would it Help
Old Jun 17, 2005 | 02:41 PM
r3v da t3g's Avatar
Default Would it Help
I have to do a smog test this month and I was wondering if I should use seafoam to clean all the carbon build up. I have read almost hundreds of threads talking about it and how it works and also the negative ones too. I have a 94 DB7 with 166,XXX, the threads I've read says 1/3 goes into the vacuum hose,1/3 into crank case, and 1/3 into full gas tank. The negative response are ones about not using seafoam on a high mileage car cause it might case internal damage with the carbon clogging up lines etc... If anyone ever done it with their car with high mileage it would be greatful. Thanks In Advance
Old Jun 17, 2005 | 02:48 PM
numbnuts22715's Avatar
id do it. I dunno if itd help for the smog junk, but itll help your car pick up a little bit.
Old Jun 17, 2005 | 02:49 PM
Finger Lickin' good's Avatar
Default Re: Would it Help (r3v da t3g)
whats a 94 db7?
But shoot, I wouldnt worry about smog until ive failed.
Old Jun 17, 2005 | 02:55 PM
Above6K's Avatar
Are you sure you'll fail your smog test? If so I would focus on fixing the culprit of your noxious emissions before worrying about seafoam.
Old Jun 17, 2005 | 02:56 PM
r3v da t3g's Avatar
Default Re: Would it Help (D-CeReaL#4)
db7 = Four Door LS but yea i dont want to fail i just want it over with til next year Thanks for quick response im going to go get seafoam and just wait to hear more responses
SithTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 &raquo;</TD></TR><TR><TD CLASS="quote">whats a 94 db7?
a 4-door ls
Old Jun 17, 2005 | 05:15 PM
slomofo's Avatar
GDD Member
I'm a smog ref. You ever hear of "Guaranteed to pass emissions or G2P"? There's many different types, the one i'm referring to is the one in the blue box available at most parts stores. Most hondas that fail, do so due to excessive CO emitting from the exhaust, usually caused by a faulty oxygen sensor which went bad from either removing the cat or adding crappy *** fuel additives/octane boosters that don't work. G2P in a half tank of premium gas will usually pass everytime, but note, if your car currently has low emissions, this crap will make you fail for NOx(cylinder temperatures) because it will make you run lean.
I read some seafoam threads and decided to give it a shot two weeks ago on a 69 Camaro with a 454, I put it in on the dyno...MAN! That **** smokes HELLA bad! Anyway, after the smoking stopped, it pulled the same numbers as it did before, so I changed the metering valves in the edelbrock carb and added G2P, then it passed.
LOVEthatDC2
Feb 29, 2012 09:56 AM
acmoc
Dec 13, 2011 01:16 AM
integra1990ls
Sep 23, 2008 08:32 AM
Unlimitationz
May 6, 2005 03:20 PM
