is it worth it??
Old Sep 27, 2002 | 12:56 PM
slvrls's Avatar
Default is it worth it??
I jus got my first car....00 ls non-vtec an i kno jus a lil bit about the sohc engine an can make small modifications like intake valves an exhaust.....but i figure its not even worth the expense to try to make the sohc run near 200 hp.....should i jus save for an engine conversion?
[Modified by slvrls, 10:02 PM 9/27/2002]
[Modified by slvrls, 10:11 PM 9/27/2002]
Old Sep 27, 2002 | 01:35 PM
HeikDiesel's Avatar
Default Re: is it worth it?? (2000integragsr)
LS's have 2 cams bro....
Old Sep 27, 2002 | 01:41 PM
2k1 GSR's Avatar
Default Re: is it worth it?? (PhatAcuraIntegra)
LS is a dohc not a sohc
Old Sep 27, 2002 | 01:48 PM
n1ek's Avatar
Default Re: is it worth it?? (slvrls)
you seem to know enough about the sohc ls motor.
just start dumping money into stuff. like a vvt-i controller.
Old Sep 27, 2002 | 07:22 PM
slvrls's Avatar
Default Re: is it worth it?? (n1ek)
hmmm....the dealer assured me it was sohc...o well....
Old Sep 27, 2002 | 07:25 PM
B18_C3P0's Avatar
then again when was the last time someone trusted a dealer??
[Modified by B18_C3P0, 10:25 PM 9/27/2002]
Old Sep 27, 2002 | 07:28 PM
thaiphob's Avatar
Nikon!!!
really.............must be a dodge dealer
Old Sep 27, 2002 | 07:46 PM
rjardy's Avatar
did you look uner the hood? two big lumps on the valve cover, hee hee
Rob
Old Sep 27, 2002 | 08:03 PM
Deluzional's Avatar
Default Re: is it worth it?? (rjardy)
[QUOTE]00 ls non-vtec an i kno jus a lil bit about the sohc engine QUOTE]
HAHAha, what a bad start
Old Sep 28, 2002 | 06:50 PM
06Xrunner's Avatar
If yours is a SOHC someone really bent you over. You bought it in the castro district didn'y you?
TurboGoKart
Apr 17, 2006 08:39 PM
Eee Kay Nine
Apr 10, 2006 08:27 PM
Eg6_RcR
Jan 28, 2004 08:32 PM
$N@kE
May 27, 2003 12:20 PM
