wobble at 15-25mph
Old 02-18-2004, 05:59 AM
93IntegraRacer's Avatar
Default wobble at 15-25mph
I have a 93 teg ls and between 15-25 mph i have a wobble that you can feel pretty bad inside the car. after 25 mph it goes away. i thought it might be a bent rim but if it was wouldnt it get worse at high speeds? please can anyone help me?
Old 02-18-2004, 08:45 AM
luvinmyGSR's Avatar
Default Re: wobble at 15-25mph (93IntegraRacer)
could b ur cv joints
Old 02-18-2004, 08:48 AM
Dyno Queen's Avatar
Default Re: wobble at 15-25mph (luvinmyGSR)
wheel bearing maybe? i had one go bad it didnt wobble alot, just made ALOT of noise!
Old 02-18-2004, 09:20 AM
Default Re: wobble at 15-25mph (Dyno Queen)
i replaced the pass side axle it helped a little but the driver side looks like it is still good. ill have to check it out again or maybe replace it. thanks guys.
Old 02-18-2004, 10:26 AM
Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93IntegraRacer &raquo;</TD></TR><TR><TD CLASS="quote">i replaced the pass side axle it helped a little but the driver side looks like it is still good. ill have to check it out again or maybe replace it. thanks guys. </TD></TR></TABLE>
Its hard to tell from the OUTSIDE whether a joint is good.
Old 02-18-2004, 11:06 AM
EL Vap133's Avatar
Check to see if the rims are bent or not, also make sure your lug nuts are on tight....
collins97
04-17-2008 06:27 PM
shadohconspiracy
15
11-03-2007 09:11 PM
Hatch It
05-20-2005 10:06 PM
crx00
07-14-2004 07:25 AM
Ivan
28
07-01-2003 07:49 PM
Quick Reply: wobble at 15-25mph
