Wiring Issue HELP PLEASE!
Old Sep 29, 2006 | 12:18 PM
modifyORdie's Avatar
Default Wiring Issue HELP PLEASE!
Alright here's the problem. I was switching out radios in my two cars awhile ago and yes, my dumbass forgot to disconnect the battery. Anyways I was cutting wires and of course sparked one and didnt think much about it. I connected the new radio, and it doesn't work and neither does the clock. So i think it must be the fuse right since their both on the same circuit and I sparked them earlier. Well the fuse is fine. All the fuses are fine. And the fuse on the radio is also fine. Does anybody have any idea what could be causing the radio AND the clock not to work?
Old Sep 29, 2006 | 12:38 PM
BLKGSR24's Avatar
I'm not sure, but did you always check the fuses under the hood?
Old Sep 29, 2006 | 12:51 PM
Default Re: (BLKGSR24)
no i didnt check them under the hood because those are things for the engine and it runs fine
Old Sep 30, 2006 | 11:11 AM
Default Re: (modifyORdie)
anyone?
Old Sep 30, 2006 | 04:18 PM
Old Sep 30, 2006 | 08:31 PM
SmogKing's Avatar
What kind of stereo? Are you sure that stereo works? Try hooking up the old one and see if that one works, if so there's your problem.
Old Sep 30, 2006 | 08:36 PM
Default Re: (SmoGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoGuy &raquo;</TD></TR><TR><TD CLASS="quote">What kind of stereo? Are you sure that stereo works? Try hooking up the old one and see if that one works, if so there's your problem.</TD></TR></TABLE>
its an alpine with the ipod kit...and i know it works cause i took it out of my old civic when i sold it....and the clock isnt working either which is odd...but all the fuses are good.
Old Sep 30, 2006 | 08:40 PM
SmogKing's Avatar
I know this sounds stupid but are you turning the key to ACC? My next step would be, check for battery voltage with a multimeter(voltmeter).
Old Oct 1, 2006 | 07:07 AM
hahahaha yes the key is turned on....everything works fine, lights, windows, climate control....but the clock and radio....this one has even stumped me and its pissing me off cause its like a $350 radio just sitting there...and its driving me nuts not to have the radio when im driving...ive started singing to myself
91EF_Si
Audio / Security / Video
Dec 23, 2007 08:44 AM
scorpio1472000
Nov 27, 2007 07:15 PM
H.
Aug 24, 2006 10:19 PM
H.
Aug 22, 2006 08:56 AM
thunteg
Jan 27, 2005 05:51 PM
