Wiring diagram?
Wiring diagram?
I just bought my first 1992 integra RS. Just rebuilt in september, it runs great, starts right up, and looks good. Only problem is the guy before me installed an aftermarket radio and instead of buying an adapter, he cut the plug and wired it manually... It runs fine, there are a few things that dont work (antenna), but im not sure if they dont work because the wiring, or just broken. If anyone has a wiring diagram for the whole car that would be great, and also a link to a place that sells the stock wiring harness so I can wire it properly.. Ive done electrical so thats no problem, just have to find the correct wires. Thanks
Re: Wiring diagram?
Do you happen to have the whole car wiring diagram? I may end up just buying a book, but im not sure if they would have the whole wiring diagram in them.. So far Ive found this, but idk how accurate this is. I might start going threw these in the next few days
Code:
| ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|white or wht/blk |+ |ign harness or fusebox | | STARTER|black/white |+ |ign harness or fusebox | | IGNITION|black/yellow |+ |ign harness or fusebox | | SECOND IGNITION|blue/white |+ |ign harness or fusebox | | ACCESSORY|yellow |+ |ign harness or fusebox | | POWER LOCK|green/white |- |either kick panel *1 | | POWER UNLOCK|green/red |- |same | | PARKING LIGHTS +|red/green | |steering column | | HEADLIGHTS|red/yellow |+ |steering column | | DOOR TRIGGER|green/red *2 |- |dr kick panel/fusebox | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|green/black |- |dr kick panel/fusebox | |TRNK/HTCH RELEASE|manual | | | | TACHOMETER|blue | |distributor | | SPEED SENSE|yellow/red | |instrument cluster | | BRAKE WIRE|green/white |+ |brake pedal switch | | HORN TRIGGER|blue/red *3 |- |steering column | | WIPERS|blue and blu/yel |- |at switch | | LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door | | RF WINDOW UP/DN|blu/grn - blu/yel |A |in drivers door or dkp | | LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp | | RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp | | RADIO 12V|white/blue |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|yellow/red |+ |radio | | RADIO ILLUMINATE|red/black |+ |radio | | POWER ANTENNA|yellow/white |+ |radio | | LF SPEAKER|blu/grn - gry/blk | |radio | | RF SPEAKER|red/grn - brn/blk | |radio | | LR SPEAKER|blu/yel - gry/wht | |radio | | RR SPEAKER|red/yel - brn/wht | |radio | Notes: *1 Easier to locate at passenger kick panel. On drivers side, wires are located high in kick panel. *2 Looks like a 14 awg. wire, but is mostly insulation. *3 High-current ground. Use a relay when interfacing with this circuit.
Old Fart
Re: Wiring diagram?
This one is accurate for the radio harness, it is missing the red/black, ["K" illumination/dimmer power] hardly ever used on aftermarket HUs, be careful if you have the two brown/white leads one is the power ant. control lead the other is the right rear speaker neg.(-).
For a complete car wiring diagram you will need to pick up something like a Haynes manual, [12021] although the Haynes is not complete. 94
