Window Rattle
Old May 22, 2006 | 02:24 PM
indtegra's Avatar
Default Window Rattle
Hi,
I own an integra 94, ls (Coupe) & when I lower my windows, it makes rattling noise as if they are loose. What might be the problem ? Where Can i get it fixed ? Do anyone know someone local ? I live in milwaukee, WI.
Thanks in advance.
Old May 22, 2006 | 02:30 PM
projectac's Avatar
Default Re: Window Rattle (indtegra)
check the rubber liner .
Old May 22, 2006 | 02:41 PM
import810's Avatar
Default Re: Window Rattle (projectac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectac &raquo;</TD></TR><TR><TD CLASS="quote">check the rubber liner .</TD></TR></TABLE>
That and make sure that the rails are not bent.
Old May 22, 2006 | 02:44 PM
ghostrider dc2's Avatar
Default Re: Window Rattle (import810)
Old May 22, 2006 | 05:47 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Go to team-integra.net. theres a how to about it... the rubber guide liner falls out and will be sitting on the bottom of your door panel if you take it apart. I just did mine, just shoved it back in, i recommend glueing it.
Old May 22, 2006 | 05:53 PM
arrojj's Avatar
Default Re: Window Rattle (ForceFed_Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Go to team-integra.net. theres a how to about it... the rubber guide liner falls out and will be sitting on the bottom of your door panel if you take it apart. I just did mine, just shoved it back in, i recommend glueing it.</TD></TR></TABLE>
expletive them they kicked me out of there
Old May 22, 2006 | 05:55 PM
solareclipseauto's Avatar
Default Re: Window Rattle (arrojj)
tighten the 10mm bolts that hold it to the rail
Old May 22, 2006 | 10:30 PM
Heres the actual link for the how-to...
http://www.team-integra.net/se...D=552
pretty straight forward. Good luck
Old May 22, 2006 | 10:33 PM
ecks_fourttwo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import810 &raquo;</TD></TR><TR><TD CLASS="quote">
That and make sure that the rails are not bent.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectac &raquo;</TD></TR><TR><TD CLASS="quote">check the rubber liner .</TD></TR></TABLE>
i agree with these two cats...
Old May 23, 2006 | 05:34 AM
R-81DC2's Avatar
Default Re: Window Rattle (ecks_fourttwo)
What is the part number on the metal piece and rubber? Can't find it in the OEM diagrams
gato5254
Apr 2, 2007 12:36 AM
civiccoupe94
16
Dec 27, 2005 04:01 PM
WHiTETYPEs
Feb 9, 2005 08:57 PM
Seedc2
Jan 17, 2004 10:27 AM
. o 69 o .
Apr 28, 2003 09:47 AM
