Window question
Old Nov 1, 2004 | 08:37 PM
taffetawhitegsr's Avatar
Default Window question
hey guys i was trying to fix my window because it goes down a little bit, slows down to nearly a stop, then goes down fine. i thought this was the motor so i lubed that bish up but it didnt help. however, i saw that the window was rubbign agains teh rubber weather stripping, causing it to slow down. i put some lube on it and it goes down fine but it eventually (after a day) goes back to the fucked-up-ness. how would i fix this? TIA
Old Nov 1, 2004 | 09:27 PM
GuitarSlinger78's Avatar
Default Re: Window question (taffetawhitegsr)
The window was rubbing up on yer weatherstripping? On the door panel? Hmm If taking off the door panel and rehanging it didn't work. Check inside the door, to the rear (opposite side of speaker) there is rubber that holds the window. Sometimes this comes loose, falls off, or starts too and makes your window lag.You can just drop some strong *** glue on that and set it back up where its supposed to be. If its not any of those... ehhh loose the window. You live in Cali, I dont think it will rain anymore we've already hit our quota.
aTrOcIoUs
Sep 11, 2007 08:17 PM
smooz EK
11
Dec 5, 2006 12:08 PM
Mycroft Holmes
Mar 14, 2002 07:42 PM
