window glass install ?
Old Jan 4, 2005 | 09:37 PM
ben_eg6's Avatar
Default window glass install ?
Some jack *** just broke my friend's integra 94 4dr window last night and jacked his cd player and some more stuffs, but thanks god they didn't jack the whole car. So we're about to go to the Yunk yard and get a used one from another 4dr teg to replace it.
If anyone did this before plz put some inputs, or any installation instructions would be great. thanks
its a 94 Rs 4dr teg and the driver site window got broken.
Old Jan 4, 2005 | 10:54 PM
ben_eg6's Avatar
Default Re: window glass install ? (Eg6B18C1)
bump
Old Jan 5, 2005 | 12:09 AM
ben_eg6's Avatar
UP
Old Jan 5, 2005 | 02:23 AM
.one lane's Avatar
.likes trains
They show how to replace the windows in the haynes repair manual. If I had a scaner I would scan the pictures in, words alone don't help at all
It's located on 11-14
24. Door window glass - removal and installations
1. remove the door panel
2. lower the glass all the way down
3. carefully pry the weather-strip out of the door window opening
4. remove the bolt(s) and detach the rear run channel from the door
5. raise the window just ebought to access the window retaining the bolts through the hole in the door frame
6. place a rag over the glass to help prevent scratching the glass and remove the two glass mounting bolts
7. remove the glass by pulling it up and out
8. installation is reverse of removal
Old Jan 5, 2005 | 04:04 PM
ben_eg6's Avatar
Default Re: (Anyone have Lube)
found it. I have a haynes manual book too, but I didn't look throught it. thanks.
328ifun
Honda Insight & CR-Z Hybrid
Oct 22, 2014 04:16 PM
VTECwalka
Apr 25, 2013 06:26 AM
acc0rdf22
Oct 8, 2009 12:17 PM
BULL3TPR00F
Aug 15, 2008 08:28 PM
Knightmare69
Apr 24, 2006 09:24 AM
