wierd e-brake light problem??
Old Oct 21, 2004 | 09:42 AM
tegsallgood's Avatar
Default wierd e-brake light problem??
every morning when i getinto my 98 LS for the past few days, i notice that when i turn the car on and release the ebrake, the 'brake' light in my console stays illuminated.
it usually stays on for a little while while driving and then shuts off randomly..
i think it might shut off when the car warms up.
nothing feels wrong and it drives, brakes and idles perfectly normal. whats the problem??
any help is appreciated
Old Oct 21, 2004 | 10:16 AM
dFreezy's Avatar
Default Re: wierd e-brake light problem?? (tegsallgood)
check your master cylinder and brake fluid levels
Old Oct 21, 2004 | 10:44 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: wierd e-brake light problem?? (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">check your master cylinder and brake fluid levels</TD></TR></TABLE>
Yup....it is an indication of your E-brake and your brake fluid being low.
Old Oct 21, 2004 | 11:22 AM
be.twenty's Avatar
wow. mines has been doing that for a while... thanks 4 the info
Old Oct 21, 2004 | 11:30 AM
Default Re: (shogun-dc2)
aight cool cool... do you think i have a leak or is it just maintenance time?
EDIT-- oh also, i park on a slightly steep hill. is that maybe the reason? im guessing that could have affected it due to the light turning off when i drive for a little while
Old Oct 21, 2004 | 11:43 AM
Mazinger's Avatar
Take off the filter/strainer in the master cylinder reservoir.
Old Oct 21, 2004 | 11:44 AM
dustrag's Avatar
i have had that prob for over a year.. thanks i wil check that now
Old Oct 21, 2004 | 11:45 AM
Radon_03's Avatar
Default Re: (tegsallgood)
i had the same problem. decided to unplug sensor on the cap. problem fixed, no more light. I just make a habit of checking my fluid once in a while. You could always go buy a new cap if you really want, that is assuming your fluid isnt low and the sensor is just messed.
Old Oct 21, 2004 | 12:38 PM
Tatakai's Avatar
Default Re: (Radon_03)
check for leaks, if u dont find any have your master cylinder checked (or u can do it if u know wtf ur doing) cuz my auto teacher told me thats the common spot where the fluid can leak and wont show visable leaking
Old Oct 21, 2004 | 01:09 PM
BlackSage's Avatar
I heard that it is just a malfunction and there is a TSB out for it. My light only comes on when the car is cold. I would thing if fluid is low there would be another "dummy" light on
Old Oct 21, 2004 | 01:17 PM
JimBlake's Avatar
Default Re: wierd e-brake light problem?? (BlackSage)
I heard about that too. TSB 03-029
MC reservoir filter 46666-S04-J02
MC reservoir float 46666-S84-999
I'm not sure firsthand whether these #s are correct. YMMV...
But I do know that the brake fluid reservoir & handbrake lever DO share the same warning-lamp circuit.
Old Oct 21, 2004 | 01:29 PM
Default Re: wierd e-brake light problem?? (JimBlake)
everyone thanks for the help.. im gonna go check everything now. but does anyone think that becuse i park on ahill overnight this could be the reason? because if im at school or a friends and it has time to cool down it never comes back on even if the engine is running cold. so thats why im assuming my levels are okay. ill check anyway tho
Old Oct 21, 2004 | 02:17 PM
dustrag's Avatar
i will check it out later 2 now i guess
Old Oct 22, 2004 | 03:48 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood &raquo;</TD></TR><TR><TD CLASS="quote">... but does anyone think that becuse i park on ahill overnight this could be the reason?</TD></TR></TABLE>Maybe the float gets crooked or something? Mine has a float that's some kinda solid plastic stuff. I'm not sure I understand how it can wedge itself sideways, but ????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood &raquo;</TD></TR><TR><TD CLASS="quote">... so thats why im assuming my levels are okay.</TD></TR></TABLE>Don't ASSUME your fluid levels are OK. It's just way too easy to look at them & then you'll be sure.
Old Oct 22, 2004 | 10:35 AM
dustrag's Avatar
I STILL NEED TO LOOK AT MINE
Old Oct 22, 2004 | 10:50 AM
BlackSage's Avatar
I went out this morning and checked the fluid. the fluid is OK but the floater was stuck. As soon as I fixed it the light went off.
Old Oct 26, 2004 | 09:48 AM
dustrag's Avatar
SAME HERE
Old Oct 26, 2004 | 11:34 AM
MugenGSR2001's Avatar
Default Re: (dustrag)
I had the same problem about 3 months ago...turned out it was a faulty distributor cap...Acura replaced it...works fine, no problem....
Old Oct 26, 2004 | 11:50 AM
IntegraBoy04's Avatar
Default Re: (MugenGSR2001)
My light never turns on, not even when the E-brake is up.
grandmasterflash
Dec 28, 2005 05:55 AM
Techna600f4i
Jun 11, 2005 05:53 PM
bucketheadCRX
Jan 9, 2005 02:20 PM
Grocery Getter
Jan 20, 2004 10:53 AM
Kid1320
Oct 1, 2003 01:23 PM
