Wich header
Old Mar 21, 2013 | 01:49 PM
Yomama182691's Avatar
Default Wich header
What are some good headers for a decent price. I've seen tri y for not a bad price. Is it worth it? All stock except cold air intake and skunk 2 mani
Old Mar 21, 2013 | 08:16 PM
S2BumpsticksGSR's Avatar
Default Re: Wich header
Its pointless if that's all the mods you have-
Old Mar 21, 2013 | 08:23 PM
Those are the only mods besides full exaust till I rebuild or get new motor. Going to turbo after rebuild or motor. So this will be just a few things that will be bought and out the way and the things that won't be able to be used be either sold or stored for another build. What else an I do bolt on wise besides the header. And without header can I still get a good sounding exaust with good power gains?
Old Mar 21, 2013 | 08:29 PM
if you're going turbo in future, save for that. You can't reuse a regular header for turbo setup. You'll need a turbo manifold and good ones cost more/same as header. You'll need tons of parts to build turbo setup- research on turbo section. There's a lot more to it than just bolting it on
Old Mar 21, 2013 | 08:39 PM
B_Swapped93's Avatar
agrre^ chose a route NA or FI then buy parts accordingly.
Old Mar 22, 2013 | 07:16 AM
What is na or fi?
Old Mar 22, 2013 | 08:10 AM
All motor(naturally aspirated) or forced induction(turbo or supercharged)
Old Mar 22, 2013 | 08:33 AM
Oh ok. I'm not real sure right now. I'd like to turbo later so I guess I would need to start checking into fi
Old Mar 22, 2013 | 08:58 AM
Go to top where it says forums and select that section to check out fi stuff.
Anthony1
Honda Civic (2006 - 2015)
Jul 27, 2006 08:08 AM
stp_vtec_boi
Feb 25, 2004 05:58 PM
stp_vtec_boi
Feb 19, 2004 04:06 PM
JDMorgan
Feb 14, 2004 08:40 PM
