whine when engine is cold, please help
Old Feb 17, 2003 | 09:18 PM
b18bfreak's Avatar
Default whine when engine is cold, please help
Recently when I turn the car on in the mornings the car makes an annoying whining sound that I have not been able to pin-point. It increases as you rev the car. Goes away as engine warms up.
Anyone had this problem? What was the cause and how to fix? Thanks.
Old Feb 17, 2003 | 10:02 PM
tilt's Avatar
Default Re: whine when engine is cold, please help (b18bfreak)
a loose/wet drive belt?
Old Feb 17, 2003 | 11:06 PM
b18bfreak's Avatar
Default Re: whine when engine is cold, please help (tilt)
its not a high pitch, loud belt noise. Any other ideas?
Old Feb 18, 2003 | 10:03 AM
b18bfreak's Avatar
up
Old Feb 18, 2003 | 10:41 AM
Rtzx9r's Avatar
GDD 1%
I have a 98ls w/58K. When it is <15 degrees F and my car has sat all day outside in the wind (at school) I hear it when I start the car- for about 2 minutes. I figure it is tight bearings (water pump maybe) because the metal has shrunk due to the cold.
It also increases with revving, but I let the sucker warm up for like 2 minutes while I clean the junk off the windows.
No problems, it goes away here. HTH
Old Feb 18, 2003 | 10:55 AM
b18bfreak's Avatar
Default Re: whine when engine is cold, please help (Rtzx9r)
sounds like you have the same problem I have.
Old Feb 18, 2003 | 02:20 PM
B16sR4Kids's Avatar
It is more than likely your belts, mine does it also.
Old Feb 18, 2003 | 04:57 PM
Web_Head's Avatar
New User
Make sure your power steering pump has enough fluid in it.
Old Feb 18, 2003 | 06:53 PM
darrinbrewer's Avatar
Default Re: whine when engine is cold, please help (Web_Head)
mine sounds like a supercharger when cold -it's the header on my car though, when i installed the dc header, instantly began doing it,
Old Feb 18, 2003 | 08:47 PM
Chris's Avatar
Default Re: whine when engine is cold, please help (darrinbrewer)
Put the clutch in... does it go away?
If so, then you need a new throw out bearing.
Old Feb 18, 2003 | 09:55 PM
Type Wah's Avatar
Default Re: whine when engine is cold, please help (Chris)
When I start my car, it sounds like my computer starting. ya know that microsoft windows loading sound.. hahhaha, maybe its the chip in my ecu.. sound like a freakin pc!
Old Feb 18, 2003 | 09:59 PM
threatcon13's Avatar
New User
Default Re: whine when engine is cold, please help (Type Wah)
thats nothing to be laughing about.. well i guess thats what happens when you put a bmw tuner's "chip" onto a honda ecu.
Old Feb 18, 2003 | 10:05 PM
Type Wah's Avatar
Default Re: whine when engine is cold, please help (Threatcon13)
puhahhahhaaaa, i'm laughing about it.. so sue me
Herb
Old Feb 18, 2003 | 10:20 PM
Black99Luder's Avatar
mine sounds like a supercharger (or turbo at times) as well...but just about all the time if the throttle position is correct....I think it is my CAI, cuz i only have that and exhaust.
Old Feb 19, 2003 | 12:44 AM
ThisLittleSleepeR's Avatar
Default Re: whine when engine is cold, please help (Black99Luder)
you should install norton antivirus
Old Feb 19, 2003 | 12:51 AM
b18bfreak's Avatar
Default Re: whine when engine is cold, please help (ThisLittleSleepeR)
no one knows?
[Modified by b18bfreak, 9:52 AM 2/19/2003]
Old Feb 19, 2003 | 08:34 AM
Chris's Avatar
Helloo??? did you try that?
Old Feb 19, 2003 | 11:14 AM
b18bfreak's Avatar
already tried that.
Old Feb 19, 2003 | 11:26 AM
ebelp's Avatar
I think I know this one. If you have a bad/weak ground in your stereo, you'll get a high pitched whine that comes through your speakers. The whine should go away if you turn your stereo off. Try that...I guarantee that's what it is.
Old Feb 19, 2003 | 11:46 AM
b18bfreak's Avatar
Default Re: whine when engine is cold, please help (ebelp)
Not the stereo.
its coming from the engine bay.
When car warms up it goes away.
alba
Mar 19, 2009 02:27 PM
fryman
Aug 22, 2008 10:31 AM
krca21
Jan 29, 2007 01:54 PM
Silvteg95
Aug 8, 2005 07:31 PM
dumbchild
Aug 9, 2002 01:14 AM
