Where is it located???
Old Aug 24, 2003 | 09:02 PM
96 Ls lnTeG's Avatar
Default Where is it located???
Temperature Sensor/Switch. Can someone tell me where this is located on a 96 Ls????? anyone have any pic thanks
Oh yah I tried Search already
Old Aug 25, 2003 | 05:00 AM
Default Re: Where is it located??? (96 Ls lnTeG)
Any One?????
Old Aug 25, 2003 | 09:17 AM
JimBlake's Avatar
I don't know if they moved them around, LS vs. GS-R or '95 vs. '96, but here's how it is on my '95 GS-R...
Under the distributor, near the nozzle for the upper radiator hose, there's 2 sensors. The one with 2 wires is the ECT sensor - coolant temperature sensor for the ECM. The one with only 1 wire is the sender for the dashboard temperature gauge.
The radiator-fan switch is located in the thermostat housing. That's farther back, at the lower radiator hose.
Old Aug 25, 2003 | 09:51 AM
Default Re: Where is it located??? (JimBlake)
is it a easy fix do need to jack up th car or anything??
Old Aug 25, 2003 | 11:22 AM
JimBlake's Avatar
I'd reach them from the top. You might want to remove the air intake tube so you have more room.
Anti-freeze will come running out the hole, so just be ready to put the new one in quickly. Then maybe you'll only lose a cup or so.
NeverSummer32
Apr 26, 2015 04:31 PM
Psychoteen101
Feb 7, 2013 10:14 PM
smeister
Dec 15, 2004 06:47 AM
OneFastGsr
Aug 20, 2003 08:16 AM
