When should i shift???
Old May 2, 2005 | 10:26 PM
Methane2k2's Avatar
Default When should i shift???
I have a 92 integra gsr and my redline is at 8000rpm.....i am not sure when to shift but the couple of times ive raced i have shifted at 8100 on a stcok B17 Motor? What would be the recommened RPMs to shift??? Help Please...
Old May 2, 2005 | 10:33 PM
MR-MUGEN's Avatar
Default Re: When should i shift??? (Db2_iNtEgRa)
well that all depends on how long you want your motor to last
Old May 2, 2005 | 10:37 PM
Milanogisser's Avatar
For starters your redline is 8200 to be exact.The best thing I can tell you would be this: I too have a 92 gs-r.The b17a powerband stops climbing at 7600 rpms.7600 would be the ideal shift point.Anything after that would be a drop in the powerband and a waste of time.
Old May 2, 2005 | 10:38 PM
Old_Honda's Avatar
Default Re: When should i shift??? (Milanogisser)
Ya I only made power up to 7500 on the dyno so anything more is just noise
Old May 2, 2005 | 10:40 PM
sirg-vtec's Avatar
Default Re: When should i shift??? (OldGSR)
well not really, your tach is not correct unless you get one of those aftermarket tach thus if you shift after 7600 or at 8... you could still well be in the powerband.
Old May 3, 2005 | 05:11 AM
Integra21's Avatar
Default Re: When should i shift??? (sirg-vtec)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milanogisser &raquo;</TD></TR><TR><TD CLASS="quote">For starters your redline is 8200 to be exact.The best thing I can tell you would be this: I too have a 92 gs-r.The b17a powerband stops climbing at 7600 rpms.7600 would be the ideal shift point.Anything after that would be a drop in the powerband and a waste of time. </TD></TR></TABLE>
mostly true - it depends on where your peak torque is at. if you have to shift at 8k to have the revs fall right at the peak torque, that would be "faster" than shifting at 7600 and having your revs fall below peak torque.
if i remember correctly, peak torque for GSRs are 6,200 rpm -- however my peak torque is all the way down at 4k right now
Old May 3, 2005 | 07:16 AM
Methane2k2's Avatar
so is this website correct.....
http://www.supercars.net/garag....html
lude98SH
Jun 15, 2008 09:40 PM
bboyprelude
May 16, 2003 09:56 PM
Uman
May 15, 2003 09:45 AM
Austin
Sep 5, 2002 12:16 PM
REDMAN1322
Nov 7, 2001 06:00 AM
