When to shift?
Old Aug 25, 2004 | 10:55 AM
Understeer's Avatar
Default When to shift?
EDIT:
My question isn't at what RPM to shift out at. I already know when to shift when I'm racing at auto-x. Anyways, I wasn't clear on what I asked... I wanted to know how fast you guys move your shifter down when changing gears. You can move it ultra fast, or at a steady speed.. what do you guys do? I just want to save my syncros from wearing out.
Modified by Understeer at 9:36 PM 8/25/2004
Old Aug 25, 2004 | 10:57 AM
Sack Master's Avatar
Default Re: When to shift? (Understeer)
You really need to have someone teach you how to shift. But its supposed to be a smooth transition. Don't let the rpms drop much. Just enough so that you are close to the next rpm range to be smooth.
Old Aug 25, 2004 | 11:00 AM
Understeer's Avatar
Default Re: When to shift? (Sack Master)
I guess I should be more clear that I've been driving manual for several years now, so I don't need to be taught. However, I wanted to hear what you guys do. The car definetly feels smoother if I let the rpms drop a bit.
Old Aug 25, 2004 | 11:21 AM
aznballer's Avatar
when i shift mine it only drops 1000 rpms or less
Old Aug 25, 2004 | 11:33 AM
Default Re: (aznballer)
I know people that have been driving manuals for years and still need to be taught how to drive them.
Old Aug 25, 2004 | 12:19 PM
FlipSkater
Guest
Posts: n/a
Default Re: (Sack Master)
shift fast!
Old Aug 25, 2004 | 12:38 PM
nyo91's Avatar
Old Aug 25, 2004 | 12:49 PM
PhantomSTi's Avatar
Default Re: When to shift? (nyo91)
I usually rev it a little bit before I get into gear, so I don't bog.. I'm not sure if a cable tranny has anything to do with this because this is the only car I've daily driven that was a manual.
Old Aug 25, 2004 | 01:01 PM
luvinmyGSR's Avatar
Default Re: (FlipSkater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlipSkater &raquo;</TD></TR><TR><TD CLASS="quote">shift fast!</TD></TR></TABLE>
Old Aug 25, 2004 | 01:04 PM
94gsr_vtc's Avatar
why would you let the rpms drop? thats pointless to hold your foot on the clutch and wait for them to drop. if you revmatch and dont let the rpms drop it will be a smoother shift and is not hard on the synchros. i dont understand.....
Old Aug 25, 2004 | 01:13 PM
eric8876's Avatar
Default Re: (94gsr_vtc)
Is it bad for the transmission like using downshifting as serious braking like my freind will b coming at a turn at like 40 and right b4 put it in second and let it out slow for like a brake...it works good but is it bad on the tranny?
Old Aug 25, 2004 | 07:50 PM
PhantomSTi's Avatar
Default Re: (eric8876)
People have been doing it for a longggggg time...
Old Aug 25, 2004 | 08:09 PM
dcb16's Avatar
Default Re: (90integra05)
pointless...
Old Aug 25, 2004 | 08:13 PM
Integra97Zeke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">I know people that have been driving manuals for years and still need to be taught how to drive them.</TD></TR></TABLE>
Hahaha...so true
But back to the question at hand...shift without letting up on the gas pedal thats always fun and good for the car too
Old Aug 25, 2004 | 08:17 PM
White GSR '01's Avatar
Default Re: (Integra97Zeke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra97Zeke &raquo;</TD></TR><TR><TD CLASS="quote">
Hahaha...so true
But back to the question at hand...shift without letting up on the gas pedal thats always fun and good for the car too</TD></TR></TABLE>
I do this, it's called powershifting. Just leave your foot on the gas and get it into the next gear quick as hell. Only do it when you wanna haul *** though, I hear it's bad on the tranny. So I only do it while racing.
Old Aug 25, 2004 | 08:22 PM
riceball777's Avatar
if you racing you want to shift at redline and you want to shift as fast as possible
for normal driving you supose to let the rpm drop to the proper rmp before you left the clutch out
for example if you going 4k rmp in 2nd going 35mph and you want to shift to 3rd your supose to let the clutch out at the rpm 3rd gear is at when going 35mph. if you do perfectely you dont even need to use the clutch to put it in gear. if you shift to fast the rpm will jerk down and shifting will not be smooth. if you wait to long to shift and shift too slow the rpm will jerk up and shifting will not be smooth.
Old Aug 25, 2004 | 08:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">Are you suppose to let the RPM's drop and then shift?
For example.
2nd gear at 5000rpm, clutch in, wait for rpms to drop? and then shift into 3rd?
I am going to retract some of what I said.
If racing, take it to redline and shift as fast as possible without taking your foot off the gas. In normal driving, refer to the owners manual for the speeds to shift gears at. I use them for the most part, and it shifts very smooth. Just try not to let the RPM's drop too much. Shift quickly and work your clutch right and it will be smooth.
Old Aug 25, 2004 | 08:36 PM
Understeer's Avatar
Default Re: When to shift? (White GSR '01)
Old Aug 25, 2004 | 08:57 PM
G-bonic's Avatar
Hijacked
Ill say do a quick shift keep ur foot on gas pedal full throttle and just clutch shift, clutch shift, clutch shift before red line....
Old Aug 25, 2004 | 09:28 PM
shermanyang's Avatar
Default Re: When to shift? (Stock_LS)
when i race i usually shift at or near redline and i'm at half throttle. with an 8lbs flywheel, if i don't half throttle i redline almost instantly if i don't let off the gas a bit when out of gear.
85_305
Honda Civic (2001 - 2005)
53
Aug 4, 2009 07:57 AM
91(si)hatchey
Sep 6, 2006 08:57 AM
ronin308
Honda S2000
13
May 1, 2006 06:25 AM
joncho
Oct 4, 2004 09:47 AM
pub
Jun 27, 2002 10:43 PM
