when to get Compression test.
Old May 27, 2002 | 04:03 AM
comptechgsr's Avatar
Default when to get Compression test.
just wondering when..
and what numbers am i looking to meet.
Old May 27, 2002 | 06:11 AM
Mike B's Avatar
Default Re: when to get Compression test. (comptechgsr)
When, whenever you want. I used to do mine every oil change.
Old May 27, 2002 | 07:25 AM
Chubz's Avatar
GSR Id say around 200-230. Are u running stock pistons?
Old May 27, 2002 | 08:03 AM
Hapa DC5's Avatar
Default Re: when to get Compression test. (SuperTech)
anything above 200 is close to stock compression, if you have 200+ on all 4 cylinders, it's a strong motor.
Old May 27, 2002 | 10:44 AM
Mike B's Avatar
Default Re: when to get Compression test. (NemesisGSR)
I got a B20 and I did 208 across the board.
Old May 27, 2002 | 11:40 AM
Default Re: when to get Compression test. (Crazy Bovine)
shud i do it after 45k err 90k err suttin?
or only if it feels sluggish?!?!
Old May 27, 2002 | 12:50 PM
Cosworth's Avatar
Every other oil change is good enough if you're running your car hard. It only take max 10 minutes as long as you have the gauge. Usually, all four cylinders should read within 10% range from each other.
Old May 27, 2002 | 01:31 PM
Default Re: when to get Compression test. (Cosworth)
how much does a comp. test go for?
i found a place that will do it for 30 bucks?
that any good?
yeah.
where can i get it done for---in the bay area?
Type 56
Oct 12, 2016 11:10 AM
Azcheron
Jun 23, 2005 09:34 PM
SPOON_FED_DC_2
Apr 6, 2005 09:19 PM
lazyguy
May 5, 2002 01:36 PM
98civicEX
Apr 23, 2002 05:08 PM
