when do i start using higher grade fuel?
Old Aug 23, 2006 | 12:58 PM
endorfinch's Avatar
Default when do i start using higher grade fuel?
the title of the post pretty much says it but i was just wondering as your modding your car when is a good poit or at what point should i switch to a higher grade fuel or do i ever have to switch to higher grade fuel.
Old Aug 23, 2006 | 01:07 PM
atg1290's Avatar
I think it has something to do with cr and your nternals but i wanna know so bump it..
Old Aug 23, 2006 | 01:27 PM
Dartanian's Avatar
Default Re: when do i start using higher grade fuel? (endorfinch)
Anytime your setup is prone to detonation such as with higher compression ratios or forced induction.
Old Aug 23, 2006 | 01:51 PM
DC2 Mang's Avatar
Default Re: when do i start using higher grade fuel? (Sleeper Style)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">Anytime your setup is prone to detonation such as with higher compression ratios or forced induction.</TD></TR></TABLE>
you can run lower octane fuel but it is harder to tune and you will lose optimun performance
anything from 10:1 to 12.5:1 I would run premium fuel
Old Aug 23, 2006 | 01:54 PM
mike9571's Avatar
Default Re: when do i start using higher grade fuel? (DC2 Mang)
So, generally the higher the comp. the higher octane needed?
Old Aug 23, 2006 | 02:00 PM
DC2 Mang's Avatar
Default Re: when do i start using higher grade fuel? (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">So, generally the higher the comp. the higher octane needed?
yes unless your car has a forced induction system such as a turbo, supercharger, or nitrous
Old Aug 23, 2006 | 02:05 PM
GoldCoin's Avatar
once i put on the fully built head i didnt hesitate to use 91+ only.
Old Aug 23, 2006 | 02:08 PM
endorfinch's Avatar
so i should start using 91 once i put on my vtec head and cams or could i still run 87 safely.
Old Aug 23, 2006 | 02:10 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endorfinch &raquo;</TD></TR><TR><TD CLASS="quote">so i should start using 91 once i put on my vtec head and cams or could i still run 87 safely.</TD></TR></TABLE>
91 octane
Old Aug 23, 2006 | 04:41 PM
GoldCoin's Avatar
yes it i highy recommend it. esp if your running vtec. 91 is the highest in san diego . but i know in other places you can get higher.
Old Aug 23, 2006 | 08:02 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: when do i start using higher grade fuel? (DC TWOin IT)
If you look at the GSR cluster it says "Premium Unleaded Fuel Only" so that is what you should use.
Old Aug 23, 2006 | 09:12 PM
DA is best's Avatar
i used 91 octane all the time when i had my turbo daytona shelby, plus octane boosters
Old Aug 23, 2006 | 09:16 PM
GoldCoin's Avatar
Default Re: (DA is best)
what kind of octane boosters do you use?
Old Aug 23, 2006 | 10:10 PM
integra racr04's Avatar
i use plus....any car my family owns has always used a high grade...i think its just better and cleaner, so why not, but gas prices suck! ...
Old Aug 23, 2006 | 10:14 PM
Leo C's Avatar
Night Owl
Default Re: when do i start using higher grade fuel? (integra racr04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra racr04 &raquo;</TD></TR><TR><TD CLASS="quote">i use plus....any car my family owns has always used a high grade...i think its just better and cleaner, so why not, but gas prices suck! ... </TD></TR></TABLE>
Use regular for an LS. You will get better mileage and your car will be faster. Premium fuel is not necessary for an LS.
chrisa_1
Feb 12, 2010 04:56 PM
Hondaaaaa
Feb 16, 2008 04:16 AM
tt281gt
Mar 17, 2004 04:22 PM
toooslow
Nov 12, 2003 11:08 PM
