Wheel stud replacement on a DA
Old Aug 4, 2004 | 06:13 AM
sleepin91teg's Avatar
Default Wheel stud replacement on a DA
I searched, and read the helms manual...does anyone know if i can replace the from wheel studs on a 1991 acura integra without pulling the hub apart...i know on some hondas u can just pound out the stud and pull the new one back through...but i pounded mine and it went about 3/4" and then hit the bearing housing...so is there a way i can get it out with out removing the hub...i dont have air tools, and i put the 32mm 1 1/4" socket on and a breaker bar and couldnt get the nut to budge for nothing...What else can i try...
Old Aug 4, 2004 | 10:49 AM
Default Re: Wheel stud replacement on a DA (sleepin91teg)
Some body knows...
Old Aug 4, 2004 | 11:09 AM
BACKintheDA's Avatar
bump b/c I'd like to know as well!
Old Aug 4, 2004 | 11:18 AM
rastropovitch
Guest
Posts: n/a
Need to press the hubs out of the arms for the front... sorry.
Old Aug 4, 2004 | 11:28 AM
Default Re: Wheel stud replacement on a DA (MSchu)
DAMN, what about tap and die set, would that work on the lugs? if so what size?
cmfnelson
Nov 24, 2012 01:03 AM
fit2slo
Honda Fit
Oct 28, 2008 10:56 PM
EK FLY
Apr 5, 2006 10:43 AM
LudeyKrus
Jul 26, 2004 10:42 AM
underpressure02
Nov 12, 2003 06:14 PM
