Wheel size??
Old Nov 29, 2005 | 02:13 PM
Duster's Avatar
Default Wheel size??
Search is not working...
I am looking at picking up a set of 205/45Z R-16 for my 98 integra LS which currently has stock wheels...
I am buying these wheels because they have tires on them that are worth more than the wheels....but if i can just swap them straight over i would like to do so, please let me know...I believe the stock wheel size is 195/60 14's? but Im not sure...thanks guys!
Old Nov 29, 2005 | 02:18 PM
Kendall's Avatar
Tire size is good, I'd worry more about the bolt pattern and offset of the wheels.
Old Nov 29, 2005 | 02:49 PM
Duster's Avatar
Default Re: (Kendall)
http://vancouver.craigslist.org/pts/113854532.html
Can someone please tell me if these will fit my 98 integra LS?? Thanks guys... PM'd kendall just as he went offline
sorry for urgency just on my way out to buy these now if they will fit my car
Old Nov 29, 2005 | 03:09 PM
SlammedDC2teg's Avatar
Default Re: (Gixxerfiend)
they will fit. Also ask if you can try them on.
Old Nov 29, 2005 | 03:12 PM
Deluzional's Avatar
Default Re: Wheel size?? (Gixxerfiend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gixxerfiend &raquo;</TD></TR><TR><TD CLASS="quote">
I believe the stock wheel size is 195/60 14's? but Im not sure...thanks guys! </TD></TR></TABLE>
sorry im completely lost...youre putting 16" tires on stock wheels that you claim are 14"
Old Nov 29, 2005 | 03:14 PM
Duster's Avatar
Default Re: Wheel size?? (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">
sorry im completely lost...youre putting 16" tires on stock wheels that you claim are 14" </TD></TR></TABLE>
Sorry no, i want to put those wheels on my car, rims and tires, just wondering if they will fit good and everything...
Duster's Avatar
Default Re: (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">they will fit. Also ask if you can try them on.</TD></TR></TABLE>
Thanks man. I can't try em on because its at his house and im not about to take all 4 tires off and put new ones on without an impact gun im lazy.
I think hes putting the rims on his car with tires that are 205-15-16
Old Nov 29, 2005 | 03:16 PM
Duster's Avatar
Default Re: Wheel size?? (SlammedDC2teg)
yes...that link to craiglist. those wheels and tires i would like to buy and put them directly onto my integra (replacing stock). just wanted to make sure they fit before i spend the money on them
Old Nov 29, 2005 | 03:53 PM
95lstegman's Avatar
yes, they have the typical FWD offset and the correct bolt pattern for your car, so yes, they will fit. you don't sound like you know a whole lot about this sort of thing, so let me just remind you to make sure the directional arrows on the side of the tires that point away from the car are pointing forward when at the top of the rim (counterclockwise for the left side and clockwise for the right). you'll see what i mean if you do end up getting them. otherwise you'll sacrifice handling, a LOT of wet-weather safety, and tire life.
Old Nov 29, 2005 | 05:35 PM
integra3586's Avatar
Modified by integra3586 at 8:39 PM 11/29/2005
Old Nov 29, 2005 | 07:38 PM
Moogen Powah's Avatar
Default Re: (integra3586)
From the pictures, it looks as though they fit both 4X100 and 4X114.3 bolt patterns, based on the 8 holes that the wheels have. So, it should fit your LS, which has a 4X100 bolt pattern. The ad, however, does not include the offset, but looks like from the picture that they do have a FWD offset as mentioned previously.
Old Nov 29, 2005 | 08:44 PM
Duster's Avatar
Default Re: (Moogen Powah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">yes, they have the typical FWD offset and the correct bolt pattern for your car, so yes, they will fit. you don't sound like you know a whole lot about this sort of thing, so let me just remind you to make sure the directional arrows on the side of the tires that point away from the car are pointing forward when at the top of the rim (counterclockwise for the left side and clockwise for the right). you'll see what i mean if you do end up getting them. otherwise you'll sacrifice handling, a LOT of wet-weather safety, and tire life.</TD></TR></TABLE>
Yeh I don't know alot about tires and offsets and all that stuff...
Thanks guys, I bought the rims this evening, I will get them put on the teg on friday when i get off work early!! Thanks!!!
Alcatrax30
Oct 21, 2014 10:29 AM
bonSI
16
May 11, 2007 09:48 AM
johnclaunch
Mar 26, 2007 05:21 PM
Snafubmx234
Aug 24, 2006 02:30 PM
LS stretch
Aug 24, 2003 02:44 PM
