burning oil b18c
Old 08-26-2014, 06:10 AM
delsol-101's Avatar
Default burning oil b18c
Hello everyone thanks for taking the time read my post.
I recently swapped a b18c gsr into my 93 delsol.
The motor has great power but when vtec engages it smokes a
massive amout of oil.
I figure its oil any how because i add just about a quart weekly.
Is it a big possibility the valve seals are shot?
Old 08-26-2014, 07:04 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: burning oil b18c
All kinds of smoke will happen under full throttle. It's not uncommon for B18C's to burn oil.
Start with a compression/leakdown test.
Check the PCV valve.
What type of oil do you use?
Old 08-26-2014, 07:12 AM
turbohatch96y7's Avatar
Start with some basic grammar lessons holy **** that was tough to read
Old 08-26-2014, 07:18 AM
B serious's Avatar
^?? Were you trying to be ironic?
BronobodyhastimeforanykindofpunctuationIdontevenus espacesbecauseitsfaster
Old 08-26-2014, 07:43 AM
I no rite?
Old 08-26-2014, 06:19 PM
delsol-101's Avatar
i use honda 5/30 synthedic blend. i had a feeling could be valve seals
but pcv never came to mind ill have to swap it.
Old 08-26-2014, 06:32 PM
joey1320's Avatar
Originally Posted by delsol-101
hey guys so i have this issue with my delsol.
i swapped a b18c gsr in it and it sounds like a health motor strong and pulls hard
but my issue is wen vtec crosses around 58k cuz i have a itr ecu
it smokes and then around 7k it smokes heavy oil.
i no its oil cuz i have good gas milage but if i hit vtec several times a week i
can easily go throo a qt of oil.
i had some one follow me and any rpm under 58k soft or full throttle theres no smoke but vtec is another story.
I honestly hope you decide to sell your Del Sol and take that money for some grammar lessons. Why would anyone take the trouble to read through that whole vocabulary diarrhea and bother to help? This is beyond ridiculous...
Old 08-26-2014, 06:36 PM
collkid's Avatar
Yeah I stopped reading after the first sentence.
Old 08-26-2014, 08:28 PM
B serious's Avatar
Compression/leakdown test?
Old 08-27-2014, 06:04 AM
delsol-101's Avatar
adjusted the original post, and will be getting to the compression test later today
thanks for the replys.
Old 08-27-2014, 07:14 PM
delsol-101's Avatar
i did compression test all cylinders read 230psi warm engine.
and pcv valve replaced but still heavy smoke when vtecs engaged
Old 08-27-2014, 07:22 PM
Ferio Wdm Edition
ferio-ichi3's Avatar
Maybe your cylinder walls or rings are a bit messed up. Normal driving when everything is cool, vtec kick in, and oil passes though.
Old 08-27-2014, 08:23 PM
delsol-101's Avatar
yeah no smoke under 5800rpm
but above that especially passing 6500rpm rang the smokes heavy all wAy to redline
could changing the oil type help?
Old 09-03-2014, 04:18 PM
wunfstgsr's Avatar
replace the valve seals you can do this with the head still on! theres a new special tool for honda heads that make replacing valve seals easy. Its worth a try..
Old 09-03-2014, 08:51 PM
361 accord's Avatar
cmon dude, gimme a link to the special tool
hondas always burn a little oil in general, but especially if you are in vtec
Old 09-04-2014, 09:50 AM
wunfstgsr's Avatar
Used this to install my Skunk2 alpha valve springs and retainers! works like a charm!!
http://www.ebay.com/itm/VALVE-SPRING-COMPRESSOR-TOOL-1994-2001-HONDA-INTEGRA-/121369022006?hash=item1c42284e36&item=121369022006&pt=Motors_Automotive_Tools&vxp=mtr
delsol-101
08-31-2014 05:53 AM
serjey15
12-04-2010 07:20 PM
d!ckface
16
07-27-2007 04:35 PM
AllMotorMark
04-08-2004 06:45 AM
B18Ccivic
02-02-2003 05:25 PM
Quick Reply: burning oil b18c
