What should LS compression be?
Old Nov 2, 2003 | 11:32 AM
JDubya's Avatar
Default What should LS compression be?
I plan on testing the compression in my '98 LS soon. I'm wondering what number i should be around. Thanks
Old Nov 2, 2003 | 11:38 AM
NuclearB18B's Avatar
Default Re: What should LS compression be? (ALL MOTOR LS)
my 96 LS tested out at 190-200 across the board. i don't know if that's low, but i was told that was fine.
Old Nov 2, 2003 | 11:41 AM
JDubya's Avatar
Default Re: What should LS compression be? (ha illuminato un)
ok I think Nominal is 199 and Minimum is 135. Can anyone confirm this?
Old Nov 2, 2003 | 12:19 PM
Tb Fivel's Avatar
nominal on all honda motors is 180. as long is there is no more than a + or - 10 psi variance from cylender to cylender you have a healthy motor.
and all compression tests should be done at WOT
Old Nov 2, 2003 | 12:32 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un &raquo;</TD></TR><TR><TD CLASS="quote">my 96 LS tested out at 190-200 across the board. i don't know if that's low, but i was told that was fine.</TD></TR></TABLE>
thats pretty good..mine tested at 180 +/- 5 degrees. I think around 180 is the typical LS
Old Nov 2, 2003 | 12:36 PM
mmuller's Avatar
Mad Scientist
Default Re: What should LS compression be? (Deluzional)
my b18b had around 190
Old Nov 2, 2003 | 12:39 PM
B16OnTop's Avatar
Default Re: What should LS compression be? (mmuller)
my LSVTEC (B18b1 block, PR3 head) tested between 136-140 across all the cylinders, the car was also warmed up and i thought that was kind of low
Old Nov 2, 2003 | 01:43 PM
JDubya's Avatar
Default Re: What should LS compression be? (B16OnTop)
Wo0 wo0O I just tested it and it was good. 200, 195, 200, 200
Old Nov 2, 2003 | 02:56 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16OnTop &raquo;</TD></TR><TR><TD CLASS="quote">my LSVTEC (B18b1 block, PR3 head) tested between 136-140 across all the cylinders, the car was also warmed up and i thought that was kind of low</TD></TR></TABLE>
i dont think those numbers are good.
Old Nov 2, 2003 | 05:20 PM
B16OnTop's Avatar
Default Re: What should LS compression be? (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">i dont think those numbers are good.</TD></TR></TABLE>
no wonder my car only runs a 15.6
Old Nov 2, 2003 | 05:26 PM
J337_UNIT's Avatar
no wonder my car only runs a 15.6 </TD></TR></TABLE>
i dont know if your being sarcastic , but i think a 15.6 is pretty poor for LS/VTEC. Ive heard of guys puttin 15.6 on just a regular b18b.
Old Nov 2, 2003 | 05:27 PM
B16OnTop's Avatar
yea well i figured it was my compression, but i am also throwing a code, code 91 which is low fuel pressure so that adds to it
reallycooleg
Mar 8, 2006 09:06 PM
1320Video.
Oct 14, 2005 11:12 AM
redDAinteg
May 25, 2005 04:31 PM
vaporboy12
May 19, 2004 10:00 PM
PrOjEcTpImPcIvIc
Mar 7, 2004 12:00 PM
