what needs to be cover when cleaning engine?
Old Jul 3, 2009 | 02:08 PM
mynameizstitch's Avatar
Default what needs to be cover when cleaning engine?
ok i picked up some Gunk engine brite and degreaser at autozone and want to use it to clean up my engine bay. my concern is that what needs to be covered while i spray these stuff on my motor and engine bay. i would assume the battery and distributor would need to be covered up since they cant be wet while starting the car back up. what else would i need to cover up also? instruction says to spray and let it sit for 10 minutes then flush it down with a water hose.
Old Jul 3, 2009 | 02:17 PM
dntnedvtec's Avatar
Default Re: what needs to be cover when cleaning engine?
Cover you intake filter, (If aftermarket) Your distributor, and that should be good. I covered both when I washed it down. WAIT!! Might not be important, but what do you drive?? with Mods?? just wondering...
Old Jul 3, 2009 | 02:37 PM
will i got a eg6 with a b16a3 swap
Old Jul 3, 2009 | 02:46 PM
ek-g6's Avatar
Definitely cover distributor, Battery, and yes air intake if aftermarket, also cover timing belt if the cover is not there. Be careful not to spray a powerful stream of water that might get everywhere.
Old Jul 3, 2009 | 03:27 PM
94LS_allmota's Avatar
for sure dist,alternator, and becareful not to wet ure alarm siren if u have one
Old Jul 3, 2009 | 05:27 PM
94 ls-r's Avatar
The battery does not need to be covered. Intake and dizzy. Also be careful around the spark plug tubes. I seen a guy get water in them, pull the plug and let it all run in cylinder, and bent a rod cause he tried to start it. If water gets in them use compressed air to blow it out. Also run the engine just lond enough to get it a little warm before you use the cleaner. Makes it work alot better. But dont spray on the exhaust LOL!
Old Jul 3, 2009 | 09:24 PM
dntnedvtec's Avatar
engine degreaser + hot exhaust manifold = bad smelly air. JUst don't get it ever where.
baller14k
Detailing
Oct 1, 2011 05:19 PM
Oknoe.
Apr 27, 2010 07:54 PM
polishedturd
Mar 6, 2008 11:45 AM
jdm_dc_fan
Jun 30, 2006 01:50 PM
Seks
22
Oct 29, 2002 05:09 PM
