What kind of transmission fluid should i use for acura integra 95
I wanted to know what kind of transmission fluid i need to drain and refill my transmission... and how many i should buy?
Re: What kind of transmission fluid should i use for acura integra 95 (FawkFace562)
Since your new, i wont throw a fit. But any 10w30 oil 10w40 oil and hondas own manual transmission fluid will work fine. If you have a grind when you shift (mostly into 3rd) get gm friction modified syncromesh.
Re: What kind of transmission fluid should i use for acura integra 95 (.Nairb)
How come honda trannys in integras always have a third gear grind. (not to thread jack or anything) I also tried gm syncromesh and it still grinds
In my 240sx i used Redline MTF ( i believe it was the "liteweight" version)
Anyways, that **** was awesome, i felt like it took tens of thousands of miles off my dying tranny, and shifted smoother on the track and street. Has anyone here used that for Honda products? Id like to put that **** in my Integra but id like some feedback first....
Re: What kind of transmission fluid should i use for acura integra 95 (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg »</TD></TR><TR><TD CLASS="quote">How come honda trannys in integras always have a third gear grind. (not to thread jack or anything) I also tried gm syncromesh and it still grinds </TD></TR></TABLE>
Did you get the "friction modified" syncromesh? The regular syncromesh isnt going to do **** for ur grind. The friction modified stuff is like 35$.
Darth ModerVader
Re: What kind of transmission fluid should i use for acura integra 95 (saleen288)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleen288 »</TD></TR><TR><TD CLASS="quote">yeah i have that problem too, so that gm oil really works or just prolongs the grind?</TD></TR></TABLE>
Well it isn't going to "repair" anything, but people have found that it helps to alleviate the grinding symptoms.
ya i used the friction modified kind, i guess my syncros are just on their way out....
I hate to point out the obvious here, but.... The guy never specified if he had an auto or a manual and everyone is just telling him what to use. Good call guys. Call me dumb for not being clairvoyant but I never just assume anything.
Re: What kind of transmission fluid should i use for acura integra 95 (Sack Master)
yeah i just looked back at it the thread after awhile and i didnt specify it... i have an automatic so i know i need honda ATF but still i need instructions on how to do the flush or drain and refill... its been like 50 K miles already and i havent changed my transmission oil... help me out guys.
Re: What kind of transmission fluid should i use for acura integra 95 (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Buy three quarts of Honda MTF. </TD></TR></TABLE>
honda mtf, but if in a jam(temp) 10w30 motor oil. honda mtf is a synthetic oil and has additives for you syncros.
honda mtf or gm syncromesh. I had a grind in 5th and syncromesh did the job.
2 - 2.25 quarts of H mnaul tramission fluid. thers always gona be like .5 in ur trany unless u hold it up and drain it all over night..
Re: (burnout8488)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout8488 »</TD></TR><TR><TD CLASS="quote">ITS AUTOMATIC!!!!</TD></TR></TABLE>
Ok simple enough, Honda ATF No need to get the panties in a bunch.
1JDMDOMINICAN
09-23-2005 12:38 PM
94IntegraLs04
10-10-2004 02:42 PM
