what else do i need?
Old Jan 20, 2006 | 07:48 PM
97jdmdc2gsr's Avatar
Default what else do i need?
hey all, I found a set of b16b ctr cams and 99 spec itr valve springs that I want to buy. I have a 99 udsm b18c1. What else would I need to rev to 9 grand safely?
Old Jan 20, 2006 | 07:52 PM
ingrate's Avatar
25 Year Member
Default Re: what else do i need? (97jdmdc2gsr)
i can't think of any reason to go to 9000 RPM with your setup. Do the CTR cams even make power up to 9000?
Old Jan 20, 2006 | 07:53 PM
well, i was also wondering that, i shoulda added that in the question, would it be worth it?
Even if im not making more power, the fact that i can rev to 9 grand will will races cause the other guys gona have to shift alot sooner.
edit sorry i relized how gay and ricerish this sounds, but im serious...
Old Jan 20, 2006 | 08:37 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: what else do i need? (ingrate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ingrate &raquo;</TD></TR><TR><TD CLASS="quote">i can't think of any reason to go to 9000 RPM with your setup. Do the CTR cams even make power up to 9000?</TD></TR></TABLE>
I would guess that the power at 9000 RPM is nearly equal to the power at 7000 RPM. Is an optimized shift point a good enough reason?
Old Jan 20, 2006 | 10:11 PM
Default Re: what else do i need? (Dogginator)
ok so, do i need itr retainers? or anything else? and I obviously need to do something with the ecu, but im not sure whats the easiest way?
Old Jan 21, 2006 | 12:24 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97jdmdc2gsr &raquo;</TD></TR><TR><TD CLASS="quote">
not quite. if you are revving where you have no power, you wont be accellerating much, while they are shifting into their powerband and kicking your butt.
Old Jan 21, 2006 | 06:33 AM
Dogginator's Avatar
Daisy... Daisy...
ITR and GSR retainers are identical. Check part numbers here:
http://www.acuraparts247.com
The important things are the ITR intake valves, the ITR valve springs, and the ITR lost motion assemblies.
Old Jan 21, 2006 | 10:00 AM
is there any good links to sites where to get itr valves and motion assemblies? Also can I just buy a chip for my ecu to allow me to rev to 9? or what do i do for my computer.
thanks for all the help
Old Jan 21, 2006 | 10:06 AM
Dogginator's Avatar
Daisy... Daisy...
What car do you have?
Old Jan 21, 2006 | 10:08 AM
well i have a 97rs, with a 99 b18c1. If it matters
aem power pullies
aem cold air
unortidox under drive pulley
b&m fuel pressure regulator
dc header
dc exhaust
clutch masters stage 3
Old Jan 21, 2006 | 10:12 AM
Dogginator's Avatar
Daisy... Daisy...
I assume that you have an OBDII P72 ECU. You'll need to switch to ODBI. Look into Hondata, Crome, or Uberdata for chipping. You can search here or read some information on this site:
http://www.pgmfi.org
Unfortunately, it is currently down.
Old Jan 21, 2006 | 10:26 AM
shorto85's Avatar
With your setup it would be pointless to rev to 9000.
I guess once you start losing races then you will change your mind.
Im just curious but why do people want to rev so high these days? Just last week I remember seeing a guy who wanted to build his motor so it could hold 12k RPM. Now on a serious race motor yeah sure... but on a daily driver... cmon people
Old Jan 21, 2006 | 10:35 AM
ok, but if a civic type-r and integra type-r make power that high, and i have there intire valve train and cams, why wouldnt i make power up there too, not to mention i plan to do all the computer, fuel, and timing work to make it worth it.
Old Jan 21, 2006 | 10:42 AM
shorto85's Avatar
Default Re: (97jdmdc2gsr)
Maybe you should do some reading...
http://www.team-integra.net/se...D=286
http://www.team-integra.net/se...D=467
Old Jan 21, 2006 | 10:51 AM
ok, i no how peak hp power works and I know that I may not be making power that high, but like dogginator said, by reving high when i do shift into the next gear im already reving higher making more power, so thus it would be worth the little bit of high end power loss in order to get a higher start in rpm in the next gear.
Old Jan 21, 2006 | 10:52 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (shorto85)
Honda engines, especially the DOHC VTEC engines, have their peak HP very close to the redline. Therefore the optimal shift point is at the rev limiter for the stock engine. By extending the rev range slightly, the HP at the RPM for gear n equals the HP at the RPM for gear n+1. It is an optimized shift point. Yes, the power is declining from the peak HP when you continue to rev higher, however, that power is still greater than say the power at 6000RPM for a GSR.
The expression "you are not making power that high" is a falicy. You are still making power, just less than peak. Detroit iron has been doing this for years.
zigg_1311
Aug 9, 2007 01:23 PM
timelimit
10
Jul 25, 2005 06:05 PM
hott-nix
Sep 20, 2004 11:12 PM
VtecDA9
11
Aug 28, 2003 07:35 PM
crooked muffler
May 13, 2003 07:33 PM
