What Is THis???
Old Feb 8, 2009 | 11:54 AM
Bsharpe's Avatar
Default What Is THis???
What is in front of the cold air intake filter ann next to the radiotor to the left? The while resivor? Please and thanks
Old Feb 8, 2009 | 12:14 PM
Toe_Knee's Avatar
Default Re: What Is THis???
Coolant overflow tank.
Old Feb 8, 2009 | 12:15 PM
Bsharpe's Avatar
So its just a safty ? You dont have to fill it?
Old Feb 8, 2009 | 12:22 PM
LaCuRa's Avatar
i got a question 4 u, whats with the 2 hoses coming out ur valve cover?
Old Feb 8, 2009 | 12:25 PM
HondaGuy951's Avatar
oil catch can lines
Old Feb 8, 2009 | 12:56 PM
Toe_Knee's Avatar
There should be a line you fill it too. Mines pretty full.
Old Feb 8, 2009 | 01:02 PM
Bsharpe's Avatar
What so you will the over fill too?
Old Feb 8, 2009 | 01:04 PM
96teggynonVtec's Avatar
its a coolant overflow tank... Its shouldn't be anywhere near full. I believe there is a maximum line on there... which shows the max amount of coolant which should be in there.
Old Feb 8, 2009 | 01:09 PM
Bsharpe's Avatar
Sorry but so thier has to be coolant in the raditor and the over flow tank?
Old Feb 8, 2009 | 01:20 PM
hayabusa160's Avatar
thats to vent the crank case pressure.
Old Feb 8, 2009 | 03:40 PM
paton5g's Avatar
Yes there has to be coolant in the overflow tank. When the coolant gets hot it expands and needs somewhere to go. When the engine cools, it draws coolant back into the system to keep it full. Without this, air pockets would form in the system, which is bad.
Keep it full to the MAX line.
Old Feb 8, 2009 | 04:59 PM
Bsharpe's Avatar
Hmmm Thanks
Old Feb 8, 2009 | 06:45 PM
steveo135's Avatar
Hmmm Thanks
if there is no coolant you may have a problem... keep an eye on the level and see if it gets lower over time
Sheraizzle
Aug 16, 2016 12:27 PM
pizton
Honda CR-V & Element
Dec 14, 2010 06:52 PM
FrostyDC4
Nov 29, 2004 01:16 PM
ATS*Mark
Dec 20, 2003 09:37 PM
ScottEK
Oct 30, 2002 09:42 PM
