welded differential
Old Mar 10, 2003 | 12:26 PM
p1ccoloz's Avatar
Default welded differential
exactly how hard would it be to make turns and what now with a welded differential? Damn near impossible or just difficult? For those who dont know a welded differential makes both wheels spin at same rates FOREVER!
Old Mar 10, 2003 | 12:32 PM
reno96teg's Avatar
Default Re: welded differential (p1ccoloz)
and what would be the benefit of doing this?
Old Mar 10, 2003 | 12:35 PM
p1ccoloz's Avatar
Default Re: welded differential (reno96teg)
simple, advantage is traction , mostly for straightline, but i just wanted to know if it would be streetable. its for a possible project car.
[Modified by p1ccoloz, 9:35 PM 3/10/2003]
Old Mar 10, 2003 | 12:44 PM
reno96teg's Avatar
so you'd seriously consider absolutely ruining your car's drivability for negligible gains (if any) in the 1/4?
get traction bars or something.. welding your differential is just plain stupid.
Old Mar 10, 2003 | 02:35 PM
Sukebei Oni's Avatar
you could make turns but it would be completly unstreetable. when ever you would turn your tires would start hopping around, cause the outside wheel needs to turn faster than the inside wheel when turning. just get an LSD if you want better traction.
Old Mar 10, 2003 | 03:04 PM
VTECPWR's Avatar
Default Re: welded differential (Sukebei Oni)
Welded differential is bad idea for any car but a drag car. Handling will suck, driving around town and taking corners will suck, tire wear and wear and tear on your front suspension will suck. Seeing a trend here? Get better tires and a LSD if you want better traction.
Old Mar 10, 2003 | 03:19 PM
p1ccoloz's Avatar
it was just a thought/question and it was for a possible idea for a PROJECT car. So easy there buddy. in addition it's been proven to work, lets not be ignorant eh?
Old Mar 10, 2003 | 04:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If it's a straight drag car only (and I'm talking trailered, never driven on the street), do it.
[Modified by PatrickGSR94, 7:35 PM 3/10/2003]
Old Mar 10, 2003 | 05:03 PM
b18bfreak's Avatar
Default Re: welded differential (PatrickGSR94)
thats why limited slips are used. Give you best of both worlds.
rickeo
Apr 25, 2007 10:42 AM
JMSxAP1
Feb 8, 2004 12:16 PM
eg_nezay
73
Jul 6, 2003 12:53 AM
PM-Performance
Mar 18, 2003 04:48 AM
aaronic
Sep 21, 2002 11:09 AM
