Weird vtec problem. Please look...
Old Feb 22, 2008 | 12:52 PM
  #26
91EF_Si's Avatar
Default Re: Weird vtec problem. Please look... (all-mtr-teg)
From what I was told when I bought the car, it has stock gsr cams and aem cam gears wich 1 cam is set +1 and the other -1. Other than that header and exhaust.
Old Feb 22, 2008 | 09:42 PM
  #27
all-mtr-teg's Avatar
Default Re: Weird vtec problem. Please look... (91EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">From what I was told when I bought the car, [B]it has stock gsr cams [/Band aem cam gears wich 1 cam is set +1 and the other -1. Other than that header and exhaust.</TD></TR></TABLE>]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">Im running a chipped ecu that kicks vtec at 5200 rpm. Once it kicks it will start to act up.</TD></TR></TABLE>
Not a good combo, try a stock oem p72 ecu and see what happens.
Old Feb 22, 2008 | 09:44 PM
  #28
91EF_Si's Avatar
That could be the problem?
Old Feb 22, 2008 | 10:53 PM
  #29
Now that you got the coolant temp. sensor hooked up, reinstall a stock ecu and see what it does Im pretty sure HONDA would have placed stock vtec x-over at 5200 rpm if it were beneficial or made a GSR motor run better, but it is set at 4400 rpm for a reason.
Old Feb 22, 2008 | 10:58 PM
  #30
XSIintegra's Avatar
Combos are not your problem.
The parts may not be great for power, but they are not going to change your engagement.
Has VTEC ever worked for you reliably?
If you switched the solenoid with 12v+ and it still clicked on and off, I would trouble shoot 1 of 3 things:
Solenoid failure
Weak Oil Pressure
Faulty Wiring
Old Feb 22, 2008 | 11:00 PM
  #31
XSIintegra's Avatar
Default Re: Weird vtec problem. Please look... (XSIintegra)
raised engagement points = rice
mmmmmmmm.....BWWAAAAAAAhAAAhAAAAAA
Shouldn't be like that, if VTEC is engaged at the correct point, its switch over is rather subtle.
Old Feb 23, 2008 | 06:47 AM
  #32
91EF_Si's Avatar
Selonoid does click. Rewired basically everything. I'm leading to weak oil pressure because, my oil pan is dented so bad you can actually see the oil pick up .
Old Feb 23, 2008 | 07:53 AM
  #33
waccord99's Avatar
i had the same prob with my accord...just throwing it in their clean your egr valve and see wat happs
Marcels Kuztoms
Oct 20, 2012 06:38 PM
99jdm_itr
Nov 1, 2009 12:01 PM
91EF_Si
Feb 21, 2008 09:25 AM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
MontrealR
Sep 15, 2001 07:51 PM
