weird question
Old Jun 13, 2006 | 02:39 PM
rdssk8rcs1's Avatar
Default weird question
anything wrong with taking a plug wire out and checking the spark against a bolt while its running?
Old Jun 13, 2006 | 02:43 PM
VHOA's Avatar
dont take it out wile its running but yea thats how you check for spark
Old Jun 13, 2006 | 02:44 PM
rdssk8rcs1's Avatar
Default Re: (VHOA)
any real problem with taking it out while its running?
Old Jun 13, 2006 | 02:45 PM
legends's Avatar
Default Re: (rdssk8rcs1)
youll only have three cylinders with spark
Old Jun 13, 2006 | 02:49 PM
rdssk8rcs1's Avatar
Default Re: (legends)
yeah for a couple of seconds
im just asking if it could cause any problems because i did it on my buddies stock civic and a couple of minutes later it stopped running, even though after i put the wire back it was fine for a few minutes he is trying to blame it on me
Old Jun 13, 2006 | 03:22 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legends &raquo;</TD></TR><TR><TD CLASS="quote">youll only have three cylinders with spark</TD></TR></TABLE>
Exactly. It's not a real 'problem' but it's not a good idea.
Old Jun 13, 2006 | 03:39 PM
lVlemphizStylez's Avatar
Default Re: (JDM-EJ1)
im pretty sure you can blow your coil pack like that...
Old Jun 13, 2006 | 03:45 PM
-Championship-'s Avatar
76.169.175.137
Default Re: (lVlemphizStylez)
i did it with my gsr...nothing wrong happened ...i did with like 2 pistons...stupid but had to be done...turns out it was the damn distributar rotor
Old Jun 13, 2006 | 07:07 PM
rdssk8rcs1's Avatar
Default Re: (project_B18C1)
alright thanks guys any other opinions?
so you dont think i could have done any harm to it, not anything that would make the car stop running?
Old Jun 13, 2006 | 07:14 PM
magicaltrout's Avatar
i remember someone doing that while trying to test something. he fried a part of his distributor. sorry but i think you're at fault.
Old Jun 13, 2006 | 07:15 PM
if your coil blows your car will not run...
the frying of the dizzy the above poster speaks of is what i said earlier...frying the coil
Old Jun 13, 2006 | 07:30 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks guys any other opinions?
so you dont think i could have done any harm to it, not anything that would make the car stop running?</TD></TR></TABLE>
No. Sometimes, you can do this to see if a certain spark plug wire isn't getting power from the distributor like it normally should. If everything is working correctly, and you pull the wire from cylindar one, your engine will bog down. Now, assuming cylindar one wasn't firing like normal and you pulled the plug and nothing happened. You could think your distrubutor cap was bad, or maybe the spark plug, or that specific wire.
gl89
Jan 15, 2019 12:03 PM
ProjectEvilEj2
Jan 1, 2009 08:10 AM
1995sir
Jul 18, 2006 08:07 AM
hondakevin21
10
May 26, 2006 05:44 PM
TSL
Aug 12, 2005 09:52 AM
