weird problem need help!
Old Sep 17, 2013 | 01:46 PM
lowlife478's Avatar
Icon2 weird problem need help!
hi i need help with my 93 integra ls i just replaced head, timing belt, water pump,and a few gaskets in those areas but i drove fine when we cranked it then i took battery out thinking it was bad charged it and put back in then my car starting going crazy turned lights on and temp gauge rises, hit gas and it boggs down, then i checked ground from battery and fixed my problem now when i stop the car starts to cut off or will cut off then oil light comes on can somebody help me fix this please???
Old Sep 17, 2013 | 02:15 PM
lowlife478's Avatar
Default Re: weird problem need help!
anybody?
Old Sep 17, 2013 | 02:28 PM
TheRealTegger's Avatar
What?
Huh? You mean it stalls, then the oil light comes on? It doesn't stall but tries to? Do any of the other lights come on if/when it stalls, or tries to stall?
You may want to do a better job of writing, so that we know what on earth the problem actually is.
Old Sep 18, 2013 | 07:16 AM
lowlife478's Avatar
when i stop at a light or throw car in neutral, the motor cuts off and oil light comes on. I took my spark plug wires out today and they were covered in oil, and im also getting terrible gas mileage
Old Sep 18, 2013 | 07:19 AM
lowlife478's Avatar
or when i come to a stop or throw in neutral, idle will drop to a couple hundred rpm's and oil light comes on and the idle will start bouncing from 1000-200 rpm's i varies from stalling or low idle
Old Sep 19, 2013 | 03:53 AM
tamboo's Avatar
10 Year Member
http://www.rockauto.com/catalog/x,ca...,parttype,5492
Old Sep 19, 2013 | 04:26 PM
tamboo's Avatar
10 Year Member
sorry wrong grommet.
http://www.rockauto.com/catalog/x,ca...,parttype,7220
Old Sep 19, 2013 | 04:34 PM
B_Swapped93's Avatar
check timing then check for any vac leaks then check that the TPS is to spec. any CEL's ?
Old Sep 21, 2013 | 12:53 PM
lowlife478's Avatar
CELS? TPS? im not used to abbreviations
Old Sep 21, 2013 | 01:06 PM
check Engine Light(CEL) and TPS(throttle position sensor) google "how to calibrate TPS"
and how to pull codes
Old Sep 21, 2013 | 01:19 PM
lowlife478's Avatar
no codes at all.where is tps located?
and okay
Old Sep 21, 2013 | 01:57 PM
on the side of the throttle body here's link on how to calibrate/test it http://forums.g2ic.com/showthread.ph...8C-*Sir-G-spec)
Old Sep 21, 2013 | 06:43 PM
lowlife478's Avatar
it was calibrated when was on the car all i did was change the head
Old Sep 24, 2013 | 04:27 AM
Johnoolo's Avatar
Check fuses i actually had the same problem once and it was a couple fuses so try thier too.
lowlife478
Sep 18, 2013 07:22 AM
JENNY_EG6
Apr 27, 2013 12:39 PM
instructor74
Jul 8, 2008 06:05 PM
rdiggidy
Aug 17, 2004 05:16 PM
RedlineSi
May 8, 2004 09:39 AM
