Weird noise..i think its the bearing..need some advice??
Hi, i was hearing this werid noise in the car like a grinding noise and it sounded like it came from the front so i took the passenger tire off and took off the brake pads turned the axel and i hear this grinding noise...i think it is the hub bearing but im not 100 percent sure..but i sitll hearing the grinding noise. do you guys think it is the bearing?? and if so is it difficult to change?
thanks for the help
thanks for the help
