water in the trunk
Old Mar 18, 2007 | 12:41 PM
BG-Teg's Avatar
Default water in the trunk
like the title says, i poped the hatch and i noticed some stuff in my trunk was wet, i lifted the carpet and saw a good amount of water laying around the spare and the jack, are there any seals around the trunk that are notourious for going bad, and drain lines or somthing.....i dont really this **** lying in my trunk...anyhitng would help
Old Mar 18, 2007 | 01:46 PM
redGSRguy's Avatar
Default Re: water in the trunk (95tealteg)
Check the tail light gaskets or sunroof drain lines for cloggage.
Old Mar 18, 2007 | 01:53 PM
BG-Teg's Avatar
Default Re: water in the trunk (redGSRguy)
before i ask you how to check,should i just go to team-integra, just like for everything else?
Old Mar 18, 2007 | 02:13 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">Check the tail light gaskets or sunroof drain lines for cloggage.</TD></TR></TABLE>
The tail light gaskets are the most common cause.
If you see water condensation inside your taillights (just looking at them from behind the car), then that's probably what it is.
BTDT...
Old Mar 18, 2007 | 05:22 PM
BG-Teg's Avatar
Default Re: water in the trunk (nsxtasy)
ok i searched, and let the flaming begin, but where and how do you check the gaskets?
Old Mar 18, 2007 | 05:28 PM
bks84's Avatar
Loved
You gotta hydrate your trunk monkey less...
Old Mar 18, 2007 | 05:30 PM
BG-Teg's Avatar
Default Re: (4sd4dr)
yay you win the prize for having the first worthless post in this thread, anyone serious?
Old Mar 18, 2007 | 05:32 PM
bks84's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95tealteg &raquo;</TD></TR><TR><TD CLASS="quote">ok i searched, and let the flaming begin, but where and how do you check the gaskets?</TD></TR></TABLE>
Common sense says the gaskets are behind the tail lights, right? Therefore you must remove the tail lights.
To remove the tail lights there are 6 10mm nuts that hold them in place. Once you remove the plastic paneling on the rear bulk head, you'll see what Im talking about.
Old Mar 18, 2007 | 05:36 PM
BG-Teg's Avatar
Default Re: water in the trunk (4sd4dr)
now was it that hard to help me instead of the pointless post.....apology accepted
Old Mar 18, 2007 | 05:39 PM
bks84's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95tealteg &raquo;</TD></TR><TR><TD CLASS="quote">now was it that hard to help me instead of the pointless post.....apology accepted </TD></TR></TABLE>
It wasn't an apology. I was merely pointing out your lack of common sense.
Old Mar 18, 2007 | 05:49 PM
BG-Teg's Avatar
yea i kinda knew that , thats why i was being a smartass, end of thread....now
Old Mar 18, 2007 | 05:57 PM
Dogginator's Avatar
Daisy... Daisy...
I placed a small amount of RTV around the sealing lip where the taillights meet the gasket. That cured my taillight leak. My main problem was water acccmulating in my taillight.
Old Mar 19, 2007 | 04:59 AM
Integra0057's Avatar
Id check the sunroof drainage hose.. Same thing happend to my friend and we took the interior molding off and his drainage hose was pulled of the other tube which was causing it to leak into the trunk it can be easily fixed.
Old Mar 19, 2007 | 05:07 AM
efvader's Avatar
Default Re: water in the trunk (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I placed a small amount of RTV around the sealing lip where the taillights meet the gasket. That cured my taillight leak.</TD></TR></TABLE>
hondabond works wonders as well
cr-x si
26
Jan 13, 2014 10:23 PM
dnunes
Aug 28, 2011 03:50 PM
rein1116
Jun 6, 2007 07:35 PM
tytyguy
May 9, 2006 04:10 AM
95GS-R
Dec 28, 2003 03:11 PM
