Water Pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noho818 »</TD></TR><TR><TD CLASS="quote">how do i know if my water pump needs to be changed. Will My car start to over heat. i ahve a 96 gsr</TD></TR></TABLE>
how many mils on your gsr? and also u never change it once? water pump?
check water level if its ok... then check to see if u are getting any anti-freeze leaking by the front t-belt area... if no anti freeze leek then u will overheat alot or u might have a leak. If that is not the case check radiator.
Besides leaking fluid, you may also notice a squeaking sound coming from the pump... if you hear this, you definitely need to change it immediately becasue it means the bearings are going... and when they go, they'll take your T-belt with them, and that's bad news (I know from personal experience).
new_climber
16
Mar 12, 2018 08:56 PM
