water leaking problem in the 94 GSR
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
I did a search about the forum about the water leak in the passanger side floor and one of the search came out with the pics. But the only problem is that all the pics wont show. So can someone please post the pics or might be give me a clue that where's all the water coming from ? Is it hard to fix ? Thanx !!
I hope to god so because Ive spent 3 weeks trying to fix my passenger side leak and Im almost clueles right now ...Ie had the dash out ..Fender off ..Some how water is still getting into my floor ...PatrickGsr and Me seem to be the only 2 with this problem we cant fix
![](https://honda-tech.com/forums/images/smilies/emdgust.gif)
Also one more problem , i am not sure if it's related to the water leak problem but i find out that even i park my car from the afternoon till night. when i drive it at ngiht , the night temp is cool but the air that comes out from the vent is warm , I mean I didn;t even turn on the air or A/C. Doesn;t anyone have this problem before ?
You're engine is rising to temperature surprisingly quickly due to the lack of coolant in the lines. It's just a matter of time before the motor starts of overheat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbean »</TD></TR><TR><TD CLASS="quote">Also one more problem , i am not sure if it's related to the water leak problem but i find out that even i park my car from the afternoon till night. when i drive it at ngiht , the night temp is cool but the air that comes out from the vent is warm , I mean I didn;t even turn on the air or A/C. Doesn;t anyone have this problem before ?</TD></TR></TABLE>
**** same here I normally turn on the defrost so i dont have to fill it..wierd!
Under the car there is a rubber hose that leaks the condensation from the A/C to the ground and out of the car when that hose is clogged you will have clear water on the pass floor while the A/C is on just get a coat hanger and run it up that hose and try to clean it out if you have access to a compressor then shoot air up that line the hose will be more then likely under the car by the sway bar I think it will be the only one not connected to anything in that area hope that helps
![](https://honda-tech.com/forums/images/smilies/emthup.gif)
As for your other problem the air still runs threw your vents even when the car is off. Federal law mandates that air must constently flow in to the car for safety resons it is hot cause it is probebly warm out side and the air still flows near the heater core and warms up. I wouldn't worry about that only worry if foggy air comes out and smells like burnt water or the water on the floor is coolent then you have a heater core problem other wise not related.
I was a dealer tech at Nissan for 2 yrs so I have an idea on what I am talking about.
