knock sensor on LS vtec
Old Dec 20, 2005 | 10:04 PM
brian3676's Avatar
Default knock sensor on LS vtec
OK i am in the middle of installing my vtec head on my b18b block and i read that i neen a knock sensor. i was woundering if anyone knows how to over ride it with out re-programing the ECU. they say without one the engine will run, but the vtec will not kick in. if not whare is a good place to put it and can you drill it without pulling the engine. what about shavings from the drilling how do you get those out? please help, thanks brian
Old Dec 20, 2005 | 10:15 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: knock sensor on LS vtec (brian3676)
You can only overide it by switching to a piggy back or reprogramming your ecu, no other way around it.
If you drill a hole for the KS, you will get shaving and that's a no no. Just pay the extra $$ and have someone change your ecu.
Old Dec 20, 2005 | 10:43 PM
Dartanian's Avatar
Default Re: knock sensor on LS vtec (carma_626)
You don't need to drill a hole for it. Just ground it out and run the correct wires to it and it will still function.
Old Dec 21, 2005 | 04:32 PM
lsvtec90's Avatar
Default Re: knock sensor on LS vtec (Das Schmoo)
anyone have any pics on which wire and where?
xtreme-customz
Jan 6, 2006 05:09 PM
3.504
Oct 4, 2005 11:26 AM
H22A_HB
Feb 24, 2005 09:05 AM
rusureboutdat
Jul 28, 2004 10:42 PM
stubk20
Jul 6, 2004 11:59 PM
